Thread: Vectra boot lock issues
    Regular Member jsr645's Avatar
    Northants
    Default Vectra boot lock issues
    Hi, does anyone else have this problem - is it normal on the vec?
    The boot locks itself once the car is driven, so when you get out its locked, even if all the doors are unlocked. locking and unlocking the doors using the door switch doesn't do anything - you have to close the car up again and lock and unlock using the key. Is becoming annoying when you're trying to put something in or get something from the boot and the key is in the ignition etc!
    Car has autolock on so when you pull away the doors all lock, and unlock when you take the key out of the ignition. could this be it? does anyone else has autolock on and have problems with the boot?
    Also, have seen a 3 button vx key on fleebay that has boot release button - would this work with my car as it is two button - thought it might help to pop the boot rather than close doors and lock/unlock?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Do you not have a button on the on the electric window panel to open the boot?
    Northants
    no - just lock and unlock buttons
    Vehicle : SRi
    Mileage : 110000
    Mine has the left lower button to lock and unlock, and the right to unlock the boot. I did get a second switch panel the same as yours, and when I plugged it in it still worked the same as my old one. You can unlock the boot from the passenger door as well on mine.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Mine is the same as Rushy's, although the passenger switch with the lock and boot release was standard fit.
  1. Boot Lock no whirring noise and wont lock or open
    By meridianghost in forum Troubleshooting
    Last Post: 17th December 2012, 14:16
  2. Boot lock /warning issues
    By nikroc in forum Suspension, Wheels & Brakes
    Last Post: 20th June 2011, 21:05
  3. boot lock
    By alden11 in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 17:04
  4. Help. . Vectra boot lock
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 19:15
vauxhall vectra boot lock problems
