Thread: Hoe does the fuel filter come off
    Blantyre
    Default Hoe does the fuel filter come off
    I am rapidly losing patience
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by spennny View Post
    I Used a Screw driver to unclip them mate they are one **** of a clip use a thin screwie
    Blantyre
    Do you push the blue catch in ?
    Apr 2008
    Liverpool
    From what I remeber I think you do can you take a clear photo of the clips
    I ended up taking mine apart in situ - made unscrewing the cap a bot trickier as I had to use a hammer and drift to knock it round, but I could not figure out for the life of me how to get the housing out of the cradle...
    Still can't to this day, Haynes was no help either....
    Nottinghamshire
    There are 2 blue (or black) clips on each of the fuel line quick-release connectors - they are on opposite sides of the pipe and both have to be pressed in at the same time. If you can see one, the other will be hidden around the rear of the pipe.
    I don't know what car you've got but I think the clips are the same on the petrols and diesels - it's just they're near the fuel tank or under the bonnet respectively.
    HTH.
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. Fuel filter help
    By wolvesdaz in forum Engine & Drivetrain
    Last Post: 4th March 2011, 10:47
  3. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  4. fuel filter
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2007, 23:27
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
