Thread: Fault code reader query - 2002 2.2 DTi
    Nottinghamshire
    confused Fault code reader query - 2002 2.2 DTi
    I have been trying for some time to find a fault code reader that will work with my 2.2 DTi. After searching the forums, I have found plenty that won't work but I can't seem to find one that will.
    I think the main problem is that Vectra C diesels prior to 2004 are not EOBD compliant. A lot of fault code readers specifically state that they won't work with diesels prior to 2004 (or petrols prior to 2001). I found this out myself when I tried one of the RAC models from Argos - it worked fine with a 2002 GSi and a 2008 CDTi but didn't want to talk to my 2002 DTi.
    So my question is does anyone know of a fault code reader that definitely works with a pre-2004 2.2 DTi? The only options I have found so far are the 2 below, but I would like so see what else is available - and preferably cheaper - before I buy one.
    http://www.talktomycar.co.uk/products/interfaces/mj029.htm
    http://www.talktomycar.co.uk/products/advcode/mj092.htm
    Thanks!
    Nottinghamshire
    Jun 2007
    Black Country
    I got an RAC one that works on my 04 plata Signum diesel, even though its 04 plated, it was bought early in 2004 so its a dead cert its a 2003 model
    strange how it doesnt work on yours
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Have you tried this How2...........http://www.vectra-c.com/forum/showthread.php?t=81742
    Nottinghamshire
    Quote Originally Posted by John35 View Post
    Thanks for taking a look.
    I know this method works on the 3.2 V6 petrol (because I've tried it) and I think it works on the 1.8 petrol as well (as per this post). It definitely doesn't work on my 2.2 DTi (because I've tried it). There are a lot of comments on this post about types of engine that it doesn't work on (looks like most of them ).
    I think it's down to which engine management computer you have - I think it needs to be Bosch, and then maybe only certain types of Bosch...
    Mar 2012
    Exeter
    Hello,
    James, I have 2004 vectra 2.2dti and I am looking for a code reader too. So far I tried U480 and obd2 tech2 USB diagnostic tool which works with laptop and they did not work.
    If someone has dti and found the right code reader, please let us know.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    I use a cable & device which costs about 30 quid , works spot on
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    I bought a U480 which will not connect to my dti. I use Vauxcom & an ebay elm interface. Vauxcom cost about £30 iirc. It only reads codes, it doesn't do anything else.
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Oops! I meant to say I use Vauxcheck, discussing Vauxcom is forbidden.
    Nottinghamshire
    AFAIK the only genuine and properly-supported option you'll get below the cost of professional-level kit is Gendan's Vauxcheck which can read and rest fault codes on all systems except airbag. It's software and USB ELM-327 interface so you'll need a laptop to run it on. There is cheaper knock-off software and interfaces on eBay, but it's risky...
  1. For Sale: rac fault code reader
    By david-bell in forum Parts for sale
    Last Post: 14th January 2013, 18:13
  2. fault code reader?
    By andrewwelsh1958 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2012, 09:55
  3. Fault code reader
    By sixtring74 in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 16:29
  4. fault code reader
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 19th July 2010, 21:05
  5. what fault code reader do I need
    By circushead in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2010, 20:01
code reader for a vectra dti 2002
