Thread: Sonus Spot Pad advice....
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Default Sonus Spot Pad advice....
    Quick question, read a few things on this site which recommend the Sonus spot pads, so I've found the backing plate I need but the pads are SFX-1, 2 and 3 - which way round are they for coarseness..? I am after removing some fine scratches and swirls and not sure which ones I need...?
    Can anyone with these offer a tad of advice..??
    Cambridgeshire
    SONUS
    • SFX-1 Restore Medium Cut 6/10
    • SFX-2 Enhance Light Cut 3/10
    • SFX-3 Final Finish Light Cut 1/10
    There you go mate. I would buy the SFX-2 and SFX-3. When starting on your motor use the lightest cut with your polish (which polish are you going to use?) and see how it does, take it up a notch if it needs it
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by parsco View Post
    SONUS
    Was planning on using either SRP or the new Megs Swirl X, would they be ok..?
    Cambridgeshire
    The swirl X will be your best bet mate. The SRP will only cover up the swirls it will not remove them like swirl X will. Remember not to use too much, couple of skittle sized beads on the pad at a time
    Lancashire
    Trim : XP1
    Mileage : 66000
    Swirl X it is mate, thanks for your help.
    Can't wait to give this a go this week
  1. DAS-6 Machine polisher,Pads,Dodo,Megs,Hex logic,Sonus
    By bigmac in forum General items for sale
    Last Post: 23rd April 2011, 21:38
  2. Sonus white polishing pad
    By Ginge7289 in forum Detailing and Car Care Discussion
    Last Post: 31st March 2011, 22:46
  3. spot the new mod
    By SRI-RICH in forum Quick Photo Album
    Last Post: 7th May 2010, 09:52
  4. Will anyone spot me ??
    By mark_647 in forum General Chat
    Last Post: 4th March 2010, 13:15
  5. What to use to clean Sonus PC pads
    By FIL 4822 in forum Detailing and Car Care Discussion
    Last Post: 21st February 2007, 18:51
