Thread: Vec-B Brakes Droning Question
    Birmingham
    Default Vec-B Brakes Droning Question
    Morning Chap's,
    This is the second time I have noticed this now when driving at speed on the motorway.
    Basically, as im driving at 70+, say 80'ish and then press on the brakes any harder than a tap for any period longer than a split second, I get a very horrid droning sound.
    I can pinpoint if its from the front or back but you can hear it and almost feel it from the entire car.
    The pads all round are good and so are the discs.
    Can anyone help me? Dont really want to start the trial and error process.
    My car is a 51-reg Vectra B SRI DTI 130.
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Regular Member morbid movie's Avatar
    wrexham
    Vehicle : insinia
    Trim : srinav
    Engine : 160cdti
    Year : 2011
    Mileage : 11,350
    discs not warped or similar are they
    std discs?
    Birmingham
    No mate, they seem fine. No lip on them either. It only happens when doing motorway speed, they are OK around town. It is a very heavy drone when doing 70 and you press them!
    Bye bye Vec B
    - Hello Siggy!
    WGAF#5
    have you looked at the inner surfaces of the discs?? just make sure they are not "scabbed" or corroded the inner pad seems less effective than the outer one so this normally causes a build up of surface corrosion
    Birmingham
    I havent mate, but I will do the weekend. So you reckon to look at the inner side of the discs?
    Bye bye Vec B
    - Hello Siggy!
    WGAF#5
    Quote Originally Posted by Vaux-Man-G View Post
    yep - our local garage skim discs with a procut lathe - they do it with the discs in situ -
    we have losts of complaints of noises as most manufacturers now chamfer the pads to increase surface pressure as no asbestos to lubricate they subsequently end up with inner surface corrosion and lipping on the inner edge - i feel this would be the cause of your noises
    Birmingham
    Job for the weekend mee thinks! Thanks mate!
    Bye bye Vec B
    - Hello Siggy!
  1. Droning noise from wheels/brakes area?
    By Thom in forum Suspension, Wheels & Brakes
    Last Post: 4th March 2012, 18:08
  2. brakes question
    By jb-redbull in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 10:08
  3. Quick Question Brakes
    By DarylAAS in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2010, 16:45
  4. Droning front brakes
    By bygumlad in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2009, 08:15
  5. 314mm brakes question
    By Super T in forum Handling & Braking
    Last Post: 12th February 2009, 10:05
