Results 1 to 10 of 18
Thread: Halfords aircon refills
    Moray
    Default Halfords aircon refills
    My aircon is blowing warm air and the stealers want too much to re-gas, looking at halfords they sell a refill kit for £40 a mear kick in the ass compared to vauxhall.
    Has anyone used these, are they any good and how easy to refill your aircon with it?
    http://www.halfords.com/webapp/wcs/s...egoryId_165632
    May 2008
    St.Albans
    Kwik Fit only charge £45 so that might be a better option ?
    Full Member Big Sig's Avatar
    Also known as the can of death! If your system has lost all its gas - it could have! - then it needs attention to check for the leaks(s)
    Moray
    Quote Originally Posted by Impresss View Post
    I thought of them but they say they dont have the equipment and are not trained to do it in my local garage
    Moray
    System still has some gas in it , just blowing cool air not cold,
    Why is it called can of death
    Regular Member Stretchy's Avatar
    Dec 2005
    Cumbria
    How much do dealers charge? just out of curiosity
    Regular Member mcwharam's Avatar
    Oct 2007
    Leeds
    I was quoted £79 at Evans Halshaw. Kwik fit did mine for £40. They also pressure test the system to check for leaks. If there is a leak then the refill aborts - as they said the gas was poisonous?
    Glasgow
    Yeah its a highly toxic thing, i worked in a VW garage years ago and it was a bright green gunge that goes into the machine well someone knocked it over on the forecourt and it burned through the tarmac Left a permanently discoloured patch!
    Quote Originally Posted by veccysri150 View Post
    Because over charging may kill your compressor as it makes it compress a liquid - which it cannot do.
    Also if there is a leak then that needs fixing first, then it all needs to be vac'd out and refilled correctly. I would only ever use one of those cans if i were selling up!
    Full Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    wouldnt bother with a can like that! you need to remove the gas that is there, fully first before you re-gas the system.
    get it done properly for good results
    Rubbin'z racing Harry!
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. Nitrogen Tyre refills
    By Dane-10 in forum Suspension, Wheels & Brakes
    Last Post: 15th May 2012, 22:00
  3. Cartridge Refills
    By ed taylor in forum General Chat
    Last Post: 24th February 2009, 23:02
  4. Magic Tree Jet Fresh Refills
    By leeds vectra in forum General items for sale
    Last Post: 29th November 2007, 00:49
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
