Thread: Cleaning Air Flow Meter 3.2 - Any Tips / Advice?
    Regular Member Hedgehog70's Avatar
    Yorkshire
    Default Cleaning Air Flow Meter 3.2 - Any Tips / Advice?
    I have decided to clean the Bosch MAF on the Vectra in a bid to sort out my erratic varying idle speed issue
    Any tips appreciated - Method and what to use etc.
    TONY
    Bristol
    Vehicle : CDTI 150
    spray with ISO-Prop Alcohol
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Have you cleaned the TB mate. I have no real knowledge on the Z32SE but on the Z22SE an erratic idle usually points towards a dirty TB. Free to clean mate, nothing to lose.
    Yorkshire
    Yes I have cleaned the TB and changed the plugs - Never touched the MAF so will try that
    T
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Me and Andy Discoverd last night that his erratic ideling was because of his Maf.
    We unplugged it first and right away it ran at 600 revs when we plugged it back in it went up again
    Yorkshire
    Quote Originally Posted by Sean-2.2Direct View Post
    So are you replacing it or did a clean do the trick?
    T
    Apr 2008
    Liverpool
    Quote Originally Posted by Hedgehog70 View Post
    T
    Well were going to find that out im not sure what Andy is going to do yet might ask him to try cleaning it first see if it makes a differance sure he will let you know or I will when we find out
  1. Air flow meter
    By MiniVauxhall in forum Engine & Drivetrain
    Last Post: 17th April 2012, 10:38
  2. air flow meter
    By bigcarp1953 in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2011, 19:18
  3. air flow meter mod
    By adfrodsham in forum Electrical & ICE (including SatNav)
    Last Post: 3rd April 2009, 08:24
  4. air flow meter
    By Morephun in forum Engine & Drivetrain
    Last Post: 13th October 2008, 19:42
