Thread: Air box mod
    Full Member paul.sessions's Avatar
    leighton buzzard
    Default Air box mod
    hi this has probably been asked before, but ive been hearing a lot about the so-called air box mod. was wondering if someone could explain what it does how to do it, and wether it can be done on sri 2.2 dti.
    please
    thanks
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The air box mod allow more air to get into the engine more freely. It involves removing the trumpet like piece of plastic from the bottom of the air box. It is most effective when done if a K&N panel filter is also fitted although this is not essential. I have a 2.2DTi Sri and have done about 5k since doing mine and had no issues. I have also just fitted the K&N panel filter and it feels alot smoother
    Full Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    if you go to the main forum page.
    scroll down to the technical section and have a look at the "how 2's" it explains it all there.
    http://www.vectra-c.com/forum/showthread.php?t=70471
    Rubbin'z racing Harry!
    leighton buzzard
    cheers guys would i benefit from just taking the plastic bit out ?? cant afford a k&n yet..
    does it just make it smoother or does it affect engine in any other way..will it affect ecu?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Like i said i have just put in my K&N, i ran it for a good 4k before i fitted the K&N, when doing the air box mod disconnect the battery for 15mins to reset the ecu (so it can re-learn the air flow). The mod makes the car feel like it can breathe more easily, thus alot smoother on pick up.
    leighton buzzard
    cool now i understand cheers fella, did you notice anymore difference once you stuck the k&n in?? because the old air filter looks quite restrictive
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Yeah the K&N helps even more, the best mod i've done to my DTi was the steinbauer tuning box though, i've not had it on a rolling road yet but there is bags more power with it fitted
    leighton buzzard
    cheers for the help mate think i will look into the tuning box too, that sounds good
