Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Clutch Down On Start Up?
    Planet Earth
    Default Clutch Down On Start Up?
    Is this the preferred option for 1.9 CDTi's?
    Been advised that this is true (I have a 150, not sure if same applies to the 120 model).
    Regular Member DKM's Avatar
    May 2008
    Suffolk
    Its good practice in any manual vehicle, takes any pressure off gears/starter motor.
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    Quote Originally Posted by HAPPYTREE View Post
    with a good battery it makes no difference,by pressing down the clutch you take some transmission drag away,i never press my clutch down when starting my car
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Always a good idea to remove as much resistance as possible for cranking.
    Means less current draw, therefore less discharge on battery.
    Full Member spennny's Avatar
    Blantyre
    I always do this, force of habit, didnt know any of the above reasons
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    it also helps if you forget you've left it in gear
    Jun 2009
    South West
    If the car is not in gear therewill only be 5% drag not realy worth worring about. If you have the release bearing pressed against the cover plate when starting you will find the fingers will wear and then the bearing will go into the cover before you wear the clutch out.
    Ashington, Northumberland
    as mentioned above, always good practice to lighten cranking load. Also a good safety measure
    Full Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    always put clutch down, as said previous. Means you dont have to turn the whole gearbox on startup and definately a good saftey measure at the same time.
    Rubbin'z racing Harry!
    Regular Member bushygrunt's Avatar
    Wakefield
    I always press clutch down, this is actualy due to a little mistake a few years ago.
    Parked the car on the drive about 12" off the corner of the house ( as usual ) got in the next day forgot to check if it was out of gear, cranked it and the car jumped into the corner of the wall. split the bumper, dented the bonnett... we now call that day " my little ooooopps "
    So its always clutch down.... lol
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  4. Before I start does anyone know......
    By DTGB in forum Styling
    Last Post: 22nd December 2009, 10:57
  5. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
