Thread: 1.9cdti 150 and towing question
    Regular Member marky2027's Avatar
    Northumberland
    Default 1.9cdti 150 and towing question
    Thinking about taking the plunge and buying a caravan. I've bought practical caravan mag today and now trying to work out my max tow limit. I think it's 1600kg but not sure. On the ID plate I have taken the gross vehicle weight form the gross train weight. Is this right?? We have been looking at a Swift Charisma which has a MTPLM of 1475kg. Any thoughts from fellow caravanners??
    May 2007
    West Yorkshire
    if you are new to towing then 85% of the kerbweight is the general rule
    http://www.cuddles.abelgratis.net/kerbweights.htm
    http://www.cuddles.abelgratis.net/vandata.htm
    Northumberland
    Thanks for that. Looks like I was right about 1600kg for the towing weight. I know about the 85% rule but I was just concerned looking at thre legalities of towing. In the practical caravan mag it states that the MTPLM of caravan needs to be equal or less than the maximum tow limit of the car and I was unsure about the car's limits. From my workings out the swift is 96% of kerb weight of car. I like a challenge!!!
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    in the brochure it says 1600kg,the max nose weight should not exceed 78kg
    Regular Member grumpano's Avatar
    North West
    I tow a Van weighing 1425 with my Sri 150 with no problems at all mate,In fact its the best tow car I have ever had. The way you load your van is more important in my opinion,Ive seen many a huge 4 wheel drive swaying all over the motorway with a tiny caravan on the back. Due to bad loading.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Yes getting the weight ratio is a must between car and caravan. Also as stated the correct loading, all heavy items over the axle and stuff like the awning and poles in the boot off the car. You need to make your car as heavy as possible compared to the caravan. I tow a 1250kg caravan with my 2.2 dti and its very easy to break the 70 mph speed on motorways, so you have to be strict with yourself and set the cruise control at a safe speed. I usually set mine at about 65mph ish.
    The 1.9 150bhp will be even better towing due to the increase in torque.
    Northumberland
    Thanks everyone!!! Been looking at vans again today. Want one,want one...but then again I want a white Insignia Sri to pull it but dream on!!!
    Oct 2007
    Reading
    Vehicle : SAAB 93 Estate, Vectra C Estate
    Trim : LINEAR SE, Elite
    Engine : Z19DTH, Z22YH
    Year : 08,08
    Quote Originally Posted by Graham View Post
    But the towing speed limit on motorways is 60mph!
    To the OP as you seem to be new to caravanning have you actually checked to see if your licence covers you for towing?
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    [QUOTE=Inner Zone;994425]But the towing speed limit on motorways is 60mph!
    Yes it is 60mph, but all speedos read higher than the actual speed. So 65 is probably 62mph in real terms. But i also find if you stick at the indicated 60 mph on your speedo you are going at the same pace as lorries or slower.
    This i find worse because,they overtake you at a snail pace faster than you are doing then when you start going up an incline the lorry cant maintain its speed. Where as i can,and end up undertaking him while he is still trying to overtake. Hense why i travel that little bit faster to avoid the lorries overtaking.
    But ask yourself the same question do you never ever go over 70mph in your car?
    Northumberland
    Quote Originally Posted by Inner Zone View Post
    Yes my license covers me thanks
  1. 1.9cdti question about the turbo
    By andreitone in forum Engine & Drivetrain
    Last Post: 26th February 2012, 17:22
  2. 1.9CDTi engine question
    By fishphone in forum Engine & Drivetrain
    Last Post: 3rd January 2012, 23:30
  3. Another towing question
    By paulcdti150 in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2011, 21:55
  4. Vehicle Towing question
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2008, 13:32
  5. Towing Question
    By AJA in forum General Chat
    Last Post: 15th June 2007, 20:10
