Results 1 to 10 of 25
Thread: white stuff on my oil cap? vectra 3.2
    asdasd
    Default white stuff on my oil cap? vectra 3.2
    bAsically theres white creamy stuff when i take of my oil cap. took it to mechanic and he said that there was A BIT of water mixing with the oil but nothing to worry about?
    Is this something to worry about? and Why is this happening..? is there a cure?Would realllly help to know. Thanks
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    well thats normaly a classic head gasket thats away.
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Do you do short runs around town? It may just be condensation from the engine heating up and cooling down alot.
    Jun 2009
    South West
    I agree that is very normal on short trips causing condensation in the rocker cover. On the vectra B petrols there was a breather mod kit to stop this.
    Regular Member gromit's Avatar
    Cumbernauld
    Don't worry as mine did this. The next time you go for a long drive, check it when you stop and it should be away. If it was the head gasket then all the oil would usually be creamy. Take the dip stick out and check the oil and it should be dark brown or black if its not been changed for a while.
    May 2006
    scotland
    The 3.2 is famed for this. I looked at 2 and they were both like this. I was told it was something to do with the raised filler spout being cooler. I had this years ago with a rover 3.5 V8 that had a raised filler spout and it lasted 15 years with no engine problems. You are probs ok.
    Regular Member denzilbud's Avatar
    cambridge
    shouldnt be anything to worry about keep an eye on it though
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Quote Originally Posted by wickedwillie View Post
    That is right, the raised filler neck causes cooler air to run around it, you can take the raised neck off nad just use the cap directly onto the rocker cover......problem solved!
    Regular Member RMDveccy's Avatar
    yorks
    Vec 3.2 .... we all know what you do late at night on your driveway with your bonnet up.
    I personally think its not normal how much you love your car
    white creamy stuff on your oil cap huh... indeed
    Regular Member adfrodsham's Avatar
    lincoln
    you can take the filler neck off and it shouldnt do it again
  1. Vectra c stuff
    By new boy in forum General Chat
    Last Post: 13th July 2012, 12:46
  2. Proper detail on my Vectra finished with Lusso Oro. Stunning Stuff!
    By Taffyopel in forum Detailing and Car Care Discussion
    Last Post: 2nd April 2010, 19:59
  3. Green Stuff or Red Stuff Pads?
    By redraptor_141 in forum Handling & Braking
    Last Post: 21st August 2009, 18:44
  4. More Wrongly advertized Vectra Stuff....
    By BigMan in forum General Chat
    Last Post: 26th October 2007, 13:29
