Thread: Crankshaft Sprocket Bolt 1.9 cdti signum
    Apr 2009
    leicester
    Default Crankshaft Sprocket Bolt 1.9 cdti signum
    Could someone advise me in which way to undo the crankshaft sprocket bolt on a signum 1.9 cdti, Haynes says left hand thread and i have read on here normal right hand thread.
    i have moved it a couple of notches by turning clockwise but would like conformation.
    Thanks in advance
    Alan
    Mileage : 000
    I am not sure which direction it is. But I belive it is VERY tight.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    left hand thread ...and tighten to 340nm
    Mileage : 000
    That is tight then.
    Apr 2009
    leicester
    Cheers guys just didn't want to make it any tighter than it already is.
    i will tackle it again next week as i believe i need a replacement bolt.
    Feb 2006
    dudley
    whats wrong with it ?
    Bristol
    Vehicle : CDTI 150
    Thought it was only the Corsa that had a LH thread... Either way they are F*$!*^ tight.
    Make sure when you are undoing the bolt that you are prepared for it to release, there will be a fairly loud 'crack' and you will catapult yourself in the direction of movement, so make sure you are not to close to anything solid.
    Also use a good quality socket and breaker bar.
    A new bolt is recommended as they are 'stretch' bolts when torqued. About £12 fm Vx.
    Apr 2009
    leicester
    nothing wrong with the sprocket just the oil seal behind leaking.
    Feb 2006
    dudley
    Quote Originally Posted by alkez100 View Post
    ok ..when you have the sprocket off just inspect the inner part where the woodruff key is and dont be shocked if it is broken off ...seems to be a common problem as of late .....
  1. cdti fuel pump sprocket
    By robsveccycdti in forum Vectra C / Signum Troubleshooting
    Last Post: 14th February 2011, 15:15
  2. V6 Crankshaft bolt patterns
    By HairbearTE in forum Engine & Drivetrain
    Last Post: 8th January 2011, 01:47
  3. Need Help with Crankshaft Pulley Bolt!!
    By Paul from Derby in forum Engine & Drivetrain
    Last Post: 29th April 2007, 08:15
https:www.vectra-c.comforumshowthread.php85342-Crankshaft-Sprocket-Bolt-1-9-cdti-signum
undew z19dt main crank bolt
opel astra 1.9cdti crank central sprocket bolt
1.9 cdti crank pulley
opel astra 1.9cdti crankshaft sprocket bolt
1.9cdti crank shaft key way
astra 1.9cdti bottom pulley removal
zc vectra crank bolt
z19dt crank pulley removal site:www.vectra-c.com
19cdti removing crankshaft bolt
19 cdti crankshaft pulley bolt
z19dt crank sprocket woodruff
cdti 1.9 crankshaft bolt
how to remove a crankshaft pulley on 2008 opel astra 1.9cdti
vectra 1.9 cdti bottom crank mark
vauxhall 1.9cdti crank gear thread
thread ditection vectra 1.9 diesel lower crank pully
vauxhall insignia cdti camshaft shaft pulley
vauxhall insignia bottom pulley bolt
z19dth crankshaft seal
1.9 cdti 150 crankshaft
vauxhall zafira cdti crankshaft bolt
vectra c crankshaft pulley removal
vauxhall insignia crankshaft bolt
cdti crank pulley bolt
