Results 1 to 10 of 16
Thread: help needed please
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    Default help needed please
    i was driving my car when i went over a speed bump and i heard a loud crunch come from the drivers fromt wheel it now does it when i hit any kind of big bump on the road i have taken the wheel off and looked around and i cant see anything wrong, nothing is rattling or does not look like anything is broken
    i know darn all about cars so any help would be good, i cant even get my mehanic till teus or wed
    any ideas if you do can you put up rough prices of what it will cost so i dont get a shock
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Sounds like the good old spring breaking routine here - really common problem.
    Dont know for sure what you are looking at to fix but around 200 green notes although may be cheaper.
    Gazza4
    Trim : SRI
    Mileage : 46000
    i looked around the spring and it seemed fine
    Trim : SRI
    Mileage : 46000
    whats going on ive had the car with the mechanic and he seem to think that there is a wheel bearing gone but he has to take the 4 wheels of to find out which one it is??????? ive told him that the front drivers side makes a crunch sound when you hit a bump????
    can this actually be what is wrong
    Full Member spennny's Avatar
    Blantyre
    If your wheel bearing had gone " crunch " from the front, i dont think you could drive it..... a collapsed wheel bearing would make your wheel lie at an slight angle ?
    Am i right or wrong ??
    Full Member Big Sig's Avatar
    Its more likely to be the rad mounts or anti rollbar bushes/drop links.
    Trim : SRI
    Mileage : 46000
    sorry to be a pain in the bum
    the mechanic has got back to me and he has told me the only thing he can see wrong with the car is a wheel bearing gone on the drivers rear side , now he has actually heard the crunch noise himself he spent 6 hours looking and had all wheels off. should i get a second opinion on it.
    good thing is he has not charged me the £16 ph he normally does
    by the way is a wheel bearing hard to change (no knowledge of cars)
    Sweden
    If it's a rear wheel: quite easy to change. And not that expensive.
    Front wheel: NOT! Heavy tools are needed and the bearing itself cost a fortune...
    Trim : SRI
    Mileage : 46000
    thanks nizzehult
    Quote Originally Posted by rickeys16v View Post
    Read my other post
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
