Thread: Is this sludge?
    Regular Member sharpo's Avatar
    Jun 2009
    York
    Default Is this sludge?
    Hi folks
    Just picked up my new car and looked it over again, it's funny how you see other things after you've bought something.
    I looked in the filler cap again and noticed this black stuff that wipes off with a finger as seen.
    Is it sludge and will regular oil changes from now clean it up?
    The car has done 43k it's a 3.0 cdti.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Black stuff ??
    The more common one is a sort of creamy white 'mayo' - this is emulsifed oil - a mix of oil and water caused by short journeys. If the engine doesn't get up to full running temperature then moisture in the engine and oil (found normally in the air) doesn't 'boil off' and repeated short trips tends to cause this.
    Not come across a black version though - maybe it's a phenomenon with oil burners.
    Wales, UK
    That looks ok to me tbh
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    It just looks like an oil filer cap with a bit of oil on it, doesn't look like any problem to me.
    Mileage : 000
    Quite a common thing this "emulisied oil" if you do a lot odf short journeys.
    Jun 2009
    York
    The picture is looking into the engine.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    As long as you use modern oil, to the correct ACEA spec, changed at the correct interval, then you are unlikely to get build ups of sludge.
    Diesel oil gets very black quickly - just proves that it's doing it's job, ie carrying soot away.
    Full Member Big Sig's Avatar
    Looks normal, mine looks the same.
    Jun 2009
    York
    Ok folks, thanks, was a bit worried.
    Regular Member xrken's Avatar
    northampton
    rolleyes
    its a Diesel thats wot you get with them no probs there
  1. Sludge in header
    By GCusdin in forum Engine & Drivetrain
    Last Post: 4th December 2012, 20:18
  2. Black Sludge?
    By j15umm in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2012, 12:16
  3. sludge in oil filler cap!!!!!!!!!!!
    By TimTay in forum Engine & Drivetrain
    Last Post: 27th December 2010, 15:23
  4. White Sludge
    Last Post: 18th April 2009, 23:01
  5. Engine Oil Sludge
    By MrBond in forum Engine & Drivetrain
    Last Post: 18th February 2008, 11:11
