Thread: code reader?
    haworth
    Default code reader?
    as above, does anyone know the price to buy one and where from? mine is an `02 1.8 sxi manual, its just that to have them read is fairly pricey so i thought it may be econonimcal to buy one for myself,
    Carnoustie
    Argos have some, or take a chance on Ebay
    Ronnie
    New Member gavinthetazman's Avatar
    Jun 2009
    cumbria
    I have just bought one from ebay, cost £30 and reads the car faults ok. My car is a 52 reg 1.8 club and it read the codes from it no probs. you need to get the one with the following code U480 as it will read the can-bus codes. this is the language the car talks in. I found these scanners by typing in U480 in the search box.
    Hope this helps.
    Gavin
    haworth
    thanks guys, the reason for the post is that the temp warning light has come on but there is no loss of water and the temp gauge is reading as usual, other threads have said it may just be the sender unit in the header tank that is at fault, so it could be cheaper in the long term to just buy a decoder, thanks againfellas
    haworth
    SORRY!! the coolant level warning light
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Doubt that would set a fault. Sounds like either the sensor movement is restricted or it's not fitted properly.
    You may be able to read faults for free (1.8 seems to be able) - just look the the 'How to' section for instructions.
    haworth
    cheers ste, shall do a check tomorrow, i don`t use the car through the week {have a firms van} so no real rush thanks again
  1. Code reader
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2012, 22:05
  2. Birmingham - Code reader / live data reader
    By awilson1234 in forum Engine & Drivetrain
    Last Post: 26th September 2011, 16:55
  3. Code Reader
    By Paddy in forum Engine & Drivetrain
    Last Post: 4th April 2011, 21:21
  4. Code reader
    By Paddy in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2011, 18:21
  5. code reader
    By stevie in forum Engine & Drivetrain
    Last Post: 11th April 2008, 20:48
