Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: 2.2 dti limp and cut out
    Regular Member ptrehearn152's Avatar
    norfolk
    Default 2.2 dti limp and cut out
    has anyone found a definate cure for this model going into limp mode, revs drop to tick over (lumpy) and cutting out, the spanner light comes on (not ecu light), happens completely at random, and 2 fault readers on it and a tech2 no fault shown each time, checked intercooler pipes, vac pipes,cleaned egr,egr not sticking, cleaned inlet manifold and swirl valves replaced beromic temp sensor (excuse spelling if incorrect), the turbo boost seems a bit stiff but not sure if it should be, can lever it with a screw driver but difficult by hand, when i come off throttle to change gear i can hear a very slight hiss from somewhere but seem to remember someone on here saying thats normal can someone confirm please, the cars a 2004 2.2dti with 56k, one other thing i have noticed is in the fuse box next to the battery there is a yellow relay that gets quite warm, help please as the thing is doing my nut it as i've already spent wads of cash on it and got no where, many thanks in advance.
    norfolk
    forgot to say when this doesn't happen the car drives absolutely brilliantly, anyone got any ideas please, getting desperate now!!!!!!!!!!! heeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeelp
    norfolk
    take it no one knows then
    Jun 2009
    ireland
    my signum went into limp mode,
    Apperemtly it could be the trottle box is gummed up and need to be taken off and de gummed
    nothing showing on the diagnostics
    norfolk
    had mine off twice in under 1k miles, 1st time it was gummed up, 2nd time just a slight black sooty covering, cleaned each time but prob still exists.
    Thats a tough one without any fault codes but it seems you have done the most likely things. Could it be poor fuel? Do you always fill up at the same place? Maybe try a different garage?
    norfolk
    thanks for reply, yes thats already been sugested and i've tried various garages, im pluckung at straws as well as pulling my hair out.
    Have you had a tech 2 plugged in while the fault light is still lit? It maybe the only way if its not recording them. Mine doesn't seem to store codes either.
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    My 2.2dti has done this twice now since i bought it a month ago but at least with mine there seems to be a pattern to it.
    Both times it has happened its been when i've doing 50 through roadworks & then floored it in 5th to speed back up to 70 - spanner light came on & all power disappeared.
    Simple solution for me is not to put the pedal to the boards! It picks up quick enough using the cruise control buttons.
    Quote Originally Posted by dave300776 View Post
    That could be an air leak so the o2 sensors go out of range as they cannot adjust the fueling enough. But could equally be something else
  1. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  2. Limp mode..
    By ShaunyB23 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2011, 20:37
  3. DTI limp.
    By madman in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 19:15
  4. 2.2 dti limp
    By twaiter in forum Engine & Drivetrain
    Last Post: 6th April 2011, 08:57
  5. It keeps going limp on me!!!
    By Jobbytron in forum Engine & Drivetrain
    Last Post: 2nd February 2008, 20:17
vectra dti cut out limp mode
