Results 1 to 10 of 13
Thread: torque settings
    Oct 2006
    southampton
    15 Post(s)
    Default torque settings
    I left my Haynes manual at work and need a torque setting please. I need the setting for the bolts that hold the two halves of the caliper together, not the mounting bolts. cheers
    [Ex]Admin Duncan's Avatar
    You mean the caliper to the carrier?
    Oct 2006
    southampton
    15 Post(s)
    these 2 Duncan
    So that's the carrier to hub bolts and the caliper to carrier bolts then?
    Oct 2006
    southampton
    15 Post(s)
    I'm thinkin so Duncan....
    Oct 2006
    southampton
    15 Post(s)
    also while your here i'll ask you another question if thats ok. Can the calipers and carriers be laquered safely....
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Guide bolts 30nm
    Caliper mounting bolts 230nm
    Thats for the 285's, Haynes doesn't list 314's. HTH
    Quote Originally Posted by lizard View Post
    It must be from looking at them. If you've only removed the bolts needed to get the calipers and carriers off then that's all you would have removed - four bolts. Gimme a sec and I'll get the details for you. The carrier to hub is FFT, the caliper to carrier is not a great deal. One sec...
    Yep, just the same as painting. Just don't get it into the friction surfaces/rubber boot areas.
    Oct 2006
    southampton
    15 Post(s)
    they will all be laquered before all guide bolts, boots and bleed screws are fitted...
    Vehicle : SRi
    Mileage : 137000
    Guide bolts 30nm
    Looking through !!! it doesn't say any difference to 314's
  1. Torque settings
    By signum_rob in forum Engine & Drivetrain
    Last Post: 10th November 2011, 11:39
  2. Torque Settings
    By lizard in forum Handling & Braking
    Last Post: 21st June 2011, 17:27
  3. torque settings
    By mparks8590 in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2011, 14:10
  4. Torque settings ?
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2011, 09:50
  5. Torque settings??
    By Griff72 in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2010, 19:42
