Thread: Built in Inverter ~ Ideas
    Plymouth
    Default Built in Inverter ~ Ideas
    Ok ive had an idea to put an inverter into the car.
    I would ideally like a 3 pin plug socket somewhere down by the Passengers seat so i coudl plug in the laptop, mobile phones and everything else..
    So anyone any ideas where i could store the inverter, where to run a perm live (well somewhere where its live once the car is on) and how to maybe sink or hide the plug on the passengers side.
    Cheers guys
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    there is plenty of room behind the glove box for the inverter i would have thought and as for the plug if you were to put a single gang extension socket in the glove box then i think you could modify the lid a bit so the cable can pass through to it....
    Midlands Mod Shop - NFFC.
    Plymouth
    Quote Originally Posted by ditchp View Post
    Good idea...
    I could then easily put in a switch on the dash (instead of the TC switch)
    This could give me more options in choosing a power source a si could have a perm live and not risk running the battery flat with the transformer
    Mar 2007
    Surrey
    I put an inverter in my old nissan sunny ( laugh now, I've heard it all b4!! hehe)
    Wired it behind the glove box to an ignition live, drilled a small hole in the rear of the glove box, and put a single gang trailing socket in there.
    Simple result was to open the glove box and plug in!
    Now for your veccy, you could remove the glovebox, on the left you'll see a multi socket connector, with a bundle of wires going into it. The thicker BLACK wire is a switched live on ignition. Tap into that with a suitably rated fuse holder, and run that to your inverter. For the neg connection you can use a crimp O ring and connect it to one of the 10mm nuts just below the dashboard trim.
    If you want to put a switch in for it, run the power from the feed behind where the glove box will be, pop out the button blanks and feed it through from behind, drill your hole for the switch and connect, then feed a wire back to the inverter.
    I personally would want an illuminated switch, in which case you'd just run another earth wire from the switch to the same neg connection as the inverter.
    pm me if you need any destructions....!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Pop the socket in the roller type cup holder.
    Plymouth
    Quote Originally Posted by Schui1024 View Post
    cheers mate... i maybe calling on ur assitance in the future.
    ahhhh but then where my drinks go???
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    GOOD idea...i might beable to get her camping at PVS next year if i do this...
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What sort of power are you intent on running?
    Also, are you looking for pure sine wave or modified sine wave output from the inverter?
    Just remember that a 600 W inverter will draw 50 Amps. 300 W==> 25 Amps ETC
    So just be carefull where you take your 12V from.
  1. It's built.....
    By blues n twos in forum Insignia car chat
    Last Post: 23rd November 2010, 16:22
  2. Built in Sat nav.
    By NeilB in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2007, 17:27
  3. It's built and on it's way!!!
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2006, 22:52
