Thread: cross threaded glowplug
    Apr 2009
    stockton-on-tees
    Default cross threaded glowplug
    has any1 ever had to retap a glow plug without taking the head off if so could you please tell me the best way so no swarf drops in to the engine cheers
    Jun 2009
    Glasgow
    Small amount of grease/copper slip on the thread tap will catch the swarf bud!!!
    Apr 2009
    stockton-on-tees
    cheers bud u dont no how to get a snapped glow plug out do you ? was going to either use a bolt extractor or weld a nut on
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    go and get your hand's on an easyout.....that will help no end imo
    Midlands Mod Shop - NFFC.
    Apr 2009
    stockton-on-tees
    what is an easyout and where can i get it from??
    Trim : Get a
    like the welded bolt idea but easier, and you should be able to get one from a car spares place or try machine mart....
    Apr 2009
    stockton-on-tees
    cheers bud
    Mileage : 000
    an easyout( stud extractor) is a bit like a tap. But it doesn,t have teeth as such. But a left hand spiral. So when you put it in a pre-drilled hole and turn it, as you screw it in, it grips the "glowplug" and if it is not too tight it will unscrew it.
    Regular Member poves's Avatar
    lancashire
    From my experience , take it to an engineering company , the material the glowplugs are made from is monkey metal.
    I had one snap in my old dti , and it's still there yet.
    Easy outs are a good idea in principal , but in practice you might have problems as the plug just breaks up , then it's cylinder head off time.
    My mate has his own garage , and even he struggles with glowplugs that have snapped.
    Best advice is buy the most expensive glowplugs you can , as the cheap budget ones really are pants.
  1. threaded glow plugs help
    By muddydude in forum Engine & Drivetrain
    Last Post: 4th October 2012, 18:36
  2. Glowplug switch
    By matt_harw in forum Engine & Drivetrain
    Last Post: 9th October 2011, 13:02
  3. threaded hub and bolts!!!
    By ickleric in forum Suspension, Wheels & Brakes
    Last Post: 29th May 2011, 09:04
  4. glowplugs threaded
    By alphabravo in forum Engine & Drivetrain
    Last Post: 27th February 2011, 06:54
  5. glowplug light
    By clyde in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2011, 00:39
