Results 1 to 10 of 19
Thread: Boot light - Where is the fuse?
    Mar 2007
    Surrey
    confused Boot light - Where is the fuse?
    Have just been playing in the boot, fitting a few extra boot lights as I find the standard one to be in a stupid location, and not bright enough for my liking.
    Anyway, all fitted fine, only I left the bulb in at one point when I was cutting the wire, and it popped the fuse.
    Only thing is, I can't find which fuse!
    I've been through the manual, and there is no mention of the boot light fuse.
    Can anyone offer any ideas?
    Many thanks
    Matt
    Plymouth
    Quote Originally Posted by Schui1024 View Post
    Many thanks
    Matt
    Im not sure where the fues is but someone will be along shortly..
    Get some pics up of how bright ur boot is now!!!
    this task is on my things to do and i wanna see how others have done it
    Mar 2007
    Surrey
    Lol.. will get pics up, once it's dark, and the things work! lol.
    Also fitted some nice xenon ultra power bulbs, so should all be matching.. just need to adjust the height of the headlights a little.
    Just noticed that NONE of my interior lights are now working, the fronts, my footwells etc.. so there must be a fuse for the interior lights somewhere, but it's not listed..
    Anyone?
    Mar 2007
    Surrey
    Found it..
    Just went out with a torch, removing each fuse 1 by 1. It's in the front somewhere, will note which one when I change it. Anyway, bunged a bent wire in it and the lights come on, so just off out to get a spare fuse.
    Will post piccys up afterwards!
    yay.
    matt
    Mar 2007
    Surrey
    Smile as luck would have it
    went to the garage outside my place, with only £2.50 in my pocket. How much can fuses be?
    they only have the older style blade fuses, the bigger ones...
    but to get a 10 amp mini blade I would have had to buy a RING spare bulb kit for £8. Anyway, whilst looking at what else came with the bulb kit I found a 10 amp mini blade on the bottom of the shelf.. RESULT!
    So spent my £2.50 on dinner, which you may be able to find in the pics below!
    Can you spot my dinner in the last pic?
    It's not the tidyest job I'd like to have done, but it's getting dark and I'm hungry!
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i put another light in the boot and just used a vx standard one, and piggy backed the original fitting, ran the new feed for it around the boot liner to next to the right hand side boot pocket.....cut the hole and wham bang thankyou mam....i can see in the boot now.....a great little much needed mod indeed imo..
    and pizza for tea...lol
    Midlands Mod Shop - NFFC.
    Mar 2007
    Surrey
    I wanted to use an oem light fitting, but having lights at the front they always seem to get blocked by things in the boot, or by leaning and reaching into it.
    Ideally I would like to have surfaced mounted these where they are, rather than cable tied, but it does the job, and is not noticeable unless you're lying in the boot.
    An easy mod and about 30 mins all in. (spare the fuse searching! lol)
    Plymouth
    Looks good mate I may get this done in my week of mini modding at the end of the month
    Trim : Get a
    quick couple of pic's of mine....
    think i might put some brighter lamp's in though
    Plymouth
    thats exactly what i was going to do ditchp.. Think i may go for something brighter though..
    What voltage is the original boot light?
  1. boot fuse
    By caitlin6 in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2012, 23:39
  2. boot fuse
    Last Post: 13th December 2012, 20:49
  3. Boot light fuse number?
    By Ginge7289 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 19:11
  4. Fuse for boot light
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2011, 18:47
  5. Found boot lamp.../ fuse?
    By izonoky in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 20:46
astra h boot light fuse
where is fuse for vectra 54 boot
insignia boot light fuse
vectra c boot light
astra h boot light
Vauxhall astra fuses in boot
astra j fuse for boot light
vectra tailgate light fuse
astra mk5 boot light
astra h 1.9 boot light fuse location
fuse for footwell lights on astra j
vectra c boot light fuse
astra 2008 boot light not working
nisan almera tino boot light fuse
where is the boot light in a vectra
09 astra boot light
vauxhall astra boot light
where is the fuze for the boot light 2004 holden astra
vectra c headlight fuse in the boot
vauxhall astra 2009 what fuse for boot light
vectra c trunk lights
where is the courtesy light fuse on a vectra c
vauxhall luggage light fuse
vectra 1.9 54 boot light
2006 vauxhall astra 1.6 fuse for boot light
