Results 1 to 10 of 27
Thread: vec c air box mod
    Regular Member denzilbud's Avatar
    cambridge
    Default vec c air box mod
    hi all done the air box mod on my vectra this morning and i didnt have chance to test drive it.ive just been out in the car and the revs seem to be a bit hi,on idle its just over 1000rpm,would this bee the ecu getting use to what ive done or should i put the air box back to standard.manythanks
    cambridge
    any body
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    try disconecting the battery for about 20 min's so the ECU can clear it's self...then when you reconect it and go for a drive the now clear ECU will re-learn it's new peramiter's....
    hth
    Midlands Mod Shop - NFFC.
    cambridge
    do i just disconnect the negative or positive also my alarm wont go off will it
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Silly question, but you did put the filter back in didn't you ?
    And assuming you did, you may want to open the airbox again and just check you have the filter seated correctly.
    cambridge
    will try now mate
    Trim : Get a
    Quote Originally Posted by denzilbud View Post
    you can disconnect any terminal and no the alarm wont go off, well it didn't on my car anyway..
    cambridge
    so which shall i disconnect
    Regular Member Robbie69's Avatar
    Either is fine. Done it plenty of times and all will be fine. How old is your car? If it's older you may need the stereo code, newer will be fine.
    Robbie
    cambridge
    its a 52 plate
