Thread: 2.2 direct engine noise
    Norfolk
    Default 2.2 direct engine noise
    Sorry if this has been asked before, ive been searching the site but couldnt find anything conclusive so thought id put a vid up and see what you think!
    http://www.youtube.com/watch?v=KmYaZL0CLIw
    My car is a 2004 2.2 direct sxi.
    Only does it when the engine's cold and stops when the temp gauge gets to 80. appart from this the cars driving fine.
    Do i need a new timing chain? lifters? oil change? (which i think is soon due anyway)
    Any help very much appreiciated as if it is something serious..i want to nip it in the bud before it gets worse!!!
    Ed
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Does the sound change with revs?
    Norfolk
    Yes, it gets more frequent..still no patten to the noise though..still quite random!
    Blantyre
    I think mine sounds noisy on some days, then other days its quiet, gonna do a service this weekend, so hopefully will sound good after that
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Does the noise stop when you open the oil filler cap while the car is running?
    Norfolk
    Ill go and try...brb!!!
    Norfolk
    No, still does it...when the lid was off..it seemed to be sucking air in through the filler hole..is that normal?!
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Well that rules out the Crankcase pressure control valve and yep thats normal. Have you posted the vid on the 2.2 forum mate, they will know for sure. It could be anything from chain to needing a new manifold gasket. The site is called z22se.co.uk. This is my vid of a sticky hydraulic lifter, it goes after a few seconds.
    Norfolk
    Cheers for the help mate, ill see what they say! your engine def sounds alot smoother than mine!
    Thanks again.
  1. Sri 2.2 direct knocking noise
    By Paddy in forum Suspension, Wheels & Brakes
    Last Post: 27th August 2012, 18:33
  2. Random Ticking noise at startup 2.2 Direct
    By TheSnowMan in forum Engine & Drivetrain
    Last Post: 18th July 2012, 17:02
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. 2.2 Direct Rough Engine Noise on start up
    By Jonnie C in forum Engine & Drivetrain
    Last Post: 23rd January 2012, 19:04
  5. Oil and filter change Vectra 2.2 direct and noise from engine ??
    By jkspoff in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2011, 17:09
