Thread: unsolvable issue
    Regular Member mikesri2.2's Avatar
    Jun 2009
    cheshire
    confused unsolvable issue
    hi can some one tell me if they have had this problem fixed
    i noticed when i turn the steering wheel the display flickers
    and so do the headlights
    i have been looking through the threads to find the answer but no joy
    my vectra has been in the garage due to this fault.
    and no better
    is there any fix
    out there
    thanks
    WGAF#5
    suspect you may have a voltage issue with either the alternator or the battery - the steering being turned operates the power steering pump which in turn is powered and resulting in a loss of electrical power to other items - check all of your earths and feeds
    it would be worth readig your battey with an amp meter
    off load
    under load
    and charging
    hth
    regards
    Dez
    Does it only do it on tickover at stand still? If so then
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Dimming/ Flickering Headlamps is well known...See this post in Search section....consensus seems to be it's the load of electro hydraulic power steering pump....
    Jun 2009
    cheshire
    yes mate only does it at low revs
    garage told me it is something to do with adaptive headlights
    over my head
    its just a voltage drop when a large load is put on the system ie the electric steering
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Its normal mate. More info
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Mines does it and it had its alternator replaced with recall last year.
    Power steering pumps sap alot of power for idling speed its the same as switching the air con on/off at idle the rev counter drops/rises.
    Gazza4
  1. Air con issue
    By harts1.9design in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 11:26
  2. Possible BIG issue!!
    By Henry42 in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2011, 08:52
  3. hid issue
    By Morephun in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 10:30
  4. key fob issue
    By doghead632 in forum Bodywork & Interior
    Last Post: 25th August 2009, 10:22
  5. Another DPF Issue
    By mushy2007 in forum Engine & Drivetrain
    Last Post: 22nd December 2007, 11:26
