Thread: Fuel trim malfunction
    Regular Member tommyk999's Avatar
    May 2007
    Oxford
    Default Fuel trim malfunction
    Hi Guys
    Should i worry i just identified fault codes on my car.
    First two are Fuel trim malfunction bank 1 and bank 2
    Second is Ambient air temp sensor circuit.
    Any advise? Thx
    May 2007
    Oxford
    Anybody???
    Could be an air leak. Were the codes p0170 and p0173?
    May 2007
    Oxford
    yes 170 173
    air leak and where?
    May 2007
    Oxford
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I woukld check the MAF sensor and any leaks after it to the intake
    Its probably sucking air in through a split pipe or gasket. Failing that get the o2 sensors checked - as a last resort.
    May 2007
    Oxford
    Ok i check that
    Thank you
  1. Replies: 3
    Last Post: 9th September 2012, 18:06
  2. fuel trim bank 1 & 2 and misfire due to low fuel
    By shaunft in forum Engine & Drivetrain
    Last Post: 30th August 2012, 15:40
  3. fuel trim fault
    By jockyboy38 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd February 2012, 21:54
  4. Replies: 16
    Last Post: 3rd February 2011, 22:35
  5. emission light and fuel trim bank 1
    By pipamish in forum Engine & Drivetrain
    Last Post: 20th June 2008, 21:44
