Results 1 to 10 of 16
Thread: Coolant Mixture
    Full Member spennny's Avatar
    Blantyre
    Default Coolant Mixture
    Whats the ratio, 50/50
    Gonna do the EGR valve this week along with the full service, so want everything in place before i attack the car
    Paul
    [Ex]Admin Duncan's Avatar
    Yep, 50:50 and make sure you get the orangey stuff, not the other type (which I can't recall the colour it is).
    Blantyre
    Blue stuff.....
    Whats the difference D ?
    Orange for summer ? Or cars with AC ?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Orange is long life stuff, doesn't really need changed anyway
    Blantyre
    When you take of the EGR it empty's, so i need to change it then ,
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    When i took mine off (2.2dti) there was very little coolant in the egr valve. Possible that the coolant system needs bled. If you have no overheating issues and the existing coolant is still nice and bright orange no need to change
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    If you put the wrong stuff in an ally engine it will corrode it from inside. 2.2's heads have been known to leek coolant from the heads due to corrosion from the wrong antifreeze. Stick with the VX stuff. They only sell one type, its not that expensive and yep as said 50/50. HTH
    Wales
    Very good price on the GM stuff at Autovaux
    Regular Member hyperman's Avatar
    pontefract
    just go to your local car shop and get the red 5 star antifreeze, and i would only use about a 30% mix, there is no need to do a 50/50 mix in this country, also the red antifreeze lasts for 5 years, blue stuff only lasts 3 although most of it is now safe for alloy blocks etc...
    The Vx stuff is very reasonably priced and you can get 5l of the stuff for a decent price - I should know as I only bought some recently but I haven't got the receipt immediately to hand.
    Quote Originally Posted by spennny View Post
    Blue stuff.....
    As answered above - long life stuff and the right type for our engines.
    Quote Originally Posted by hyperman View Post
    I disagree. The Vx stuff clearly states a 50:50 mix so why use a weaker dilution?! Why risk running a weaker mixture than recommended and come a harsh winter it then doesn't protect the engine fully and ££££££ in repairs all for the sake of a few quids worth (if that) of anti-freeze.
    The Vx stuff is very reasonably priced - can't recall exactly how much it is but I bought 5l of the stuff recently and it wasn't a huge amount.
  1. coolant
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 29th August 2012, 15:39
  2. coolant going somewhere
    By pud wayman in forum Diesel Engine related
    Last Post: 28th March 2012, 08:59
  3. Coolant Top Up
    By alembicbassman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 15:54
  4. A/C and coolant... Why?
    By Zark in forum Engine & Drivetrain
    Last Post: 12th March 2008, 19:32
  5. Air/Fuel Mixture of a Diesel
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2007, 10:13
vectra c coolant dilute ratio
