Thread: led
    Regular Member dominic32's Avatar
    Oct 2007
    whitstable
    Default led
    i have red a couple of times that vectras dont like led's is this true? i want to upgrade interior bulbs and add footwell lighting front and back
    Surrey
    Only in the bulb check circuit.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    yep its true mate i wouldnt bother use mtec 501s alot better and no faults
    Regular Member Zark's Avatar
    Herts
    adding additional footwell lighting shouldn't cause you any bother... stick some led's in and run the power feed to either the interior light or some live wire behind the glovebox (for a permanent feed) (there's an excellent how to on here)
    replacing the interior lights with led bulbs is a bit of an ache... they tend to glow all the time (even when off) which i assume is down to the lower resistance of the led bulb...
    so use mtec ones for the interior lights - and sprinkle leds everywhere else!
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    run led footwell lights off the interior lights... they should be fine m8
