Results 1 to 10 of 17
Thread: Anyone tested there deadlocks?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Default Anyone tested there deadlocks?
    Just out of interest today i decided to test my deadlocks.
    Opened windows
    Double locked car.
    Pulled up lock on drivers door
    Opened door
    Got in car
    Unlocked passenger door
    Opened door
    Closed both doors
    Only now did the alarm go off.
    In my Saab i could even put my hand in the window and there was no way of unlcoking the door.
    Is the the same with all Vecs or do i have a problem?
    Cheers all
    Stephen
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    i believe the alarm needs 30 seconds or so to activate after u press the button. did u wait for a bit till u opened the doors etc?
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Nope. Will give that a go later. and let you know.
    Stephen
    [Ex]Admin Duncan's Avatar
    Yep, as Carl said the alarm doesn't activate until around 30 secs after locking (you'll see the red light on the dash alter in it's frequency).
    But if you've deadlocked the car and have been able to pull the door pin up then that's not right.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You should still be able to pull the individual car door locking pin up. You just shouldn't be able to open the deadlocked door after you have pulled it up.
    Edinburgh
    Just tried mine and as Ste says, the pin comes up but the door won't open. This happens immediately after double locking. No 30 sec wait for the deadlocking. My alarm seems to arm after about 10s though. Mine is an 06 Facelift SRi 1.9 CDTi if that matters.
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by Ste View Post
    what ste says mate, looks like its a trip to your friendly stealer
    Yep, exactly - but it was they way he worded his post....
    Quote Originally Posted by s_zigmond View Post
    Opened door...
    ...that made it sound that by pulling the pin up it had unlocked the door, hence my reply.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Yep, exactly - but it was they way he worded his post.......that made it sound that by pulling the pin up it had unlocked the door, hence my reply.
    Duncan you understood correctly.
    I can pull up the pin and this unlocks the door.
    It doesnt unlock all doors just the one whos pin i have pulled up.
    Will see what the stealers say.
    Cheers all
    Winteringham
    are you using the inside hand or outside inside will open door even when deadlocks are on for safety
  1. Tested out some new kit
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2009, 13:12
  2. Astra VXR: Tested
    By VectraV6CDTi in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2007, 10:44
  3. Tested a VXR
    Last Post: 28th October 2007, 23:24
  4. CDTi 1.9 150 SRi: Tested
    Last Post: 29th July 2006, 10:47
  5. tested
    By cyb in forum Signature & Avatar Testing
    Last Post: 9th April 2006, 16:54
