Thread: Mis firing 2003 vectra 2.0dti
    Jun 2009
    wrexham
    confused Mis firing 2003 vectra 2.0dti
    Hi,can any 1 help.Ive just bought my vectra 2.0dti 2003 and its developed a little missfire/hesitation between 1000rpm and 1500rpm.If i hold accelerator at 1200 rpm it will rev it self to 1500rpm then back to 1200rpm.
    If i disconnect temp sensor the car runs perfect but cooling fans stay on permanantely.Have changed temp sensor twice from vauxhall and no diffrence.
    Took for diagnostic yesterday and only thing found was ambient temp showing -40c and coolant temp -16c,possibly over fueling if it think its cold??
    Thanks for any replies/help
    Dez
    Plymouth
    i know its not the same car or anything.. but i had he same thing happen to a 2.0l VW BORA i had.... noone could ever find the fault.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Don't know if the DTi's possibly have separate temp sensors, i.e one to run the cooling fans and another to tell the ecu when the car is hot/cold. Possibly the latter is the one that you need to replace
    North Yorkshire
    As it is showing two temperatures that are obviously wrong, then it will not be a fault with one sensor.
    There could be a problem with the supply voltage to the two sensors, or with the module that interpretes the readings.
    There may also be a short in the wiring, but this is unlikely, if the problem is improved by unpluging a sensor, as the short would still be there.
    Jun 2009
    wrexham
    Thanks for all replys
    Cheers dez
    Jun 2009
    wrexham
    confused
    Had car in today for third time,now being told it may be fuel pump.
    Unsure about this,as if i unplug temp sensor car rins perfect.
    COULD FUEL PUMP BE AT FAULT??????
    North Yorkshire
    Sounds like they are guessing to me.
    Ask them to explain why they think it is the fuel pump.
    Jul 2009
    Notts
    Did you find the problem as mine is the same.
    north east
    2.0 dti have a habit of killing crank shaft sensors, miss fire / hunting is a symptoom normaly only once upto running temp. replace ment is £40 ish, its on the front of the engine block under the metal pipe from the intercooler to the turbo ( hence why they normal fail when hot )
  1. For Sale: Spares or Repair Vectra C 2.0DTi Elite 2003(03)
    By FLOB in forum Cars for sale
    Last Post: 1st July 2012, 16:44
  2. Vectra 2.0dti 2003 gearbox oil change?
    By Thom in forum Engine & Drivetrain
    Last Post: 10th September 2011, 10:20
  3. vectra 2.0DTI 2003 REMAP
    By yadziyad in forum Diesel Engine related
    Last Post: 22nd May 2011, 09:06
  4. car and spanner light 2003 Vectra 2.0dti help
    By circushead in forum Engine & Drivetrain
    Last Post: 29th October 2010, 20:24
  5. will vxr springs fit my 2003 2.0dti
    By delberto in forum Handling & Braking
    Last Post: 14th December 2009, 14:02
