Thread: Tyres - Run Flat, XL, ??????
    North East
    Default Tyres - Run Flat, XL, ??????
    When looking at tyres what does it mean when it says "run flat" or XL with the tyre??
    [Ex]Admin Duncan's Avatar
    Run flat is exactly that - they're designed to still let you drive if you've got a puncture - usually at reduced speed and for limited distance.
    XL is to do with the load rating, needed for heavier cars like the 3.0CDTi.
    Full Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    run flat also means it's a PIG to change a tyre!!!! cos they're so stiff!!!!
    Rubbin'z racing Harry!
    Regular Member shippers's Avatar
    Jun 2007
    driffield
    When you have run the runflat with a puncture you have to get a new tire as they are not good to repair.
    Run flat :
    These tyres cannot be repaired
    They are also a harder construction material, great for life expectancy (high mileage), but generally poor in wet conditions
    Ironically, although they may last longer in general use, it is possible to have failure after just 1 day!
    For this reason many owners with these tyres either swap over to standard tyres or purchase tyre insurance
    XL :
    Also known as reinforced
    These are designed for heavier cars
    Their construction is different from standard tyres, using four materials as against the usual five
    They also need a higher tyre pressure
    This results in a rigid dynamic and hard ride
  1. Wheel refurb, flat or not flat B4 lacquer
    By Grumpy1954 in forum Suspension, Wheels & Brakes
    Last Post: 22nd July 2011, 20:11
  2. Run Flat Tyres ?
    By 67688c in forum General Chat
    Last Post: 2nd April 2009, 17:19
  3. Run Flat Tyres
    By shippers in forum General Chat
    Last Post: 20th April 2008, 10:06
  4. Flat tyres
    By Adam in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2007, 12:55
  5. Run Flat Tyres - Good For Your Health!
    By stickshift in forum Comedy & Humour
    Last Post: 27th March 2007, 16:58
