Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: The Roof Mounted DVD Install
    Leicester
    Default The Roof Mounted DVD Install
    When I got home this evening, I decided to fit the DVD system I got from Paul (Leeds Vectra) instead of doing it on Saturday.
    Here is how I got on.
    Firstly, here is the kit when unpacked from the box.
    Here is the blank canvas to work with!
    Remove the interior light and undo the velcro clip that holds the roof lining to the roof of the car.
    Then you simply use the roof template with the correct light marking and stick it to the roof lining.
    Then the fun bit! Cutting the roof lining! Pays to be carefull here!
    Thats the hard bit done. You then take the roof mounting plate and fit the console to it using the screws provided.
    Warm the roof panel with a hair dryer until it's quite hot, peel off the double sided tape backing and stick to the roof panel. By having the console fitted, it makes it very easy to get it centrally fitted.
    Then remove the four screws and remove the console. This leaves the mounting plate in position.
    The next stage is to fit the sponge spacers which allow the console to be a snug fit to the roof lining.
    You then need to thread through the roof lining the loom. I carried this from the top of the passenger side A pillar to the centre of the roof.
    Once connected to the roof console, re-fit the roof console and tighten accordingly.
    Here is the DVD player fitted. This part of the instll is now complete.
    Once you have fed the loom down the A pillar, remove the fuse panel as pictured.
    You will then see an earth screw located at the top as pictured.
    Remove this screw and feed the earth cable in behind and refit the screw holding the earth cable securely in place.
    Final step, the power! You have two choices here, switched live or permanent. I decided to have a switched live.
    So I checked on TIS to see which fuse did what and which was on the ingnition. I piggy backed onto fuse F20 which is the instrument panel fuse. I removed the original fuse, fitted the adaptor and then put the original fuse and the DVD's 5 amp fuse in the holder.
    Keys on and all working fine!
    If you decide you want to use a pernament live, fuse F6 can be used for this.
    All in all the whole job took just over an hour to complete.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Top Banana Matt. Such a quality job.
    Another Mod that VX could have offered from the factory!!!!
    Well Done.
    Regular Member Robbie69's Avatar
    That looks brilliant, I want one!
    Regular Member stuball's Avatar
    Aberdeen
    Excellent work for an hour. Makes me want one even more
    Regular Member old cruiser's Avatar
    slough
    Looks a top job mate, well done
    Cheers Pete
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    nice mod and very neat and tidy
    Full Member paul.sessions's Avatar
    leighton buzzard
    looks smart mate bet your well chuffed
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    very nice fit matt, look's pretty factory
    Midlands Mod Shop - NFFC.
    Sunny Dartmoor
    Nice job matt,looks the business........
    Regular Member collow123's Avatar
    cumnock ayrshire
    Quality job mate looks great i agree that its just one of those extras vx should have offered ...... Only because like everything i want one
  1. DVD Roof Mounted
    By boxer6364 in forum Electrical & ICE (including SatNav)
    Last Post: 10th September 2011, 21:11
  2. Vauxhall Roof Mounted DVD
    By leeds vectra in forum Parts for sale
    Last Post: 12th June 2009, 14:11
  3. Roof Mounted DVD
    By leeds vectra in forum Electrical & ICE (including SatNav)
    Last Post: 1st May 2006, 21:48
