Thread: Spongey brakes?
    Regular Member Keith Fusco's Avatar
    County Durham
    Default Spongey brakes?
    Anyone else had this problem?
    My brakes were fine the other day and when I was driving to Darlo, they seemed to stop working as such. Was coming up to a roundabout and had to slam on for them to work properly. Even then, it seemed like they were slipping when the ABS comes on.
    Was going to book it in, but now it seems to have gone ok?
    I noticed the other week too when I press the brake in, it sounds like some air is being released. I asked my dad if his was the same and he said it was.
    His is the 07 1.8 facelift model and mine's a 57 1.9CDTi facelift model too.
    [Ex]Admin Duncan's Avatar
    Sounds like they may need bleeding/fluid replaced. If you have the engine off and pump the pedal a few times, does the pedal then go firm and not drop down at all?
    County Durham
    I think so mate, yeah. I'll have to double check the next time I'm in the car.
    Is the air noise common too? I never noticed it before, until the other day/week, so wasn't sure.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    my brakes are very spongy when warm and i can press them to the floor when the handbrake is on and hear air noise?? but if the engine is off and i pump the pedal is rock hard !!!!???
    Quote Originally Posted by Keith Fusco View Post
    Not sure if the air noise is something specific to diesels? - certainly doesn't do it on a petrol.
    Quote Originally Posted by vectragsi3.2 View Post
    Yep, that's perfectly normal - pedal will drop with the engine running if force kept applied to it, but shouldn't with engine off.
    County Durham
    Yeah, it's when the engine's on that I can hear the air noise on the brake. Only noticed it when I had the music off and coming to some traffic lights to stop.
    I think mine's the same when the engine's off.
    Even if the pedal doesn't drop when the engine's off, you reckon it'll be the brakes needing bleeding/fluid replacing?
    Regular Member Craig1985's Avatar
    harwich essex
    i have a 1.9cdti and the air noise is normal, they also are spongy, possibly diesel creep mate. its normal.
    With brakes tho mate, if your not sure always get it checked out by a mechanic. theres no second chance with brakes
  1. vxr brakes + 17s ???
    By wullie-t27 in forum Handling & Braking
    Last Post: 8th September 2012, 17:46
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. Brakes a bit on the spongey side...
    Last Post: 3rd February 2011, 20:43
  4. Spongey/weak brakes HELP!
    By sri andy in forum Suspension, Wheels & Brakes
    Last Post: 10th July 2009, 16:54
  5. spongey brakes
    By taxi kev in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2008, 22:25
