Results 1 to 10 of 11
Thread: EGR - Black Smoke - Intercooler???
    Regular Member SlimRichardson's Avatar
    Jun 2009
    Durham
    Question EGR - Black Smoke - Intercooler???
    hi all my first post here, i have read other posts with similar problems as above but aint been able to find a solution, ok here it goes...
    my car is a vectra 1.9CDTI LS Life (120) '05, over the past few months it has been losing power puffing out black clouds of smoke and the dreaded car and spanner light has been flashing up every now and again, i have taken it to 5 different garages no fault codes no one knows, also had it to vxl dealer, they cleaned the egr valve charged me £104 to do so was ok for about a week then problem started again if not getting worse so took it back and sed needed a new egr wanted to charge me £140 so got it done else where for £70 but egr was second hand, that was ok for about a week then started getting worse AGAIN and has been getting worse since, took it back to the garage had another look cant see the problem but says maybe sumthign to do with the cambust system whatever this is???? any ideas??? ive had a look at it myself and under the bumper where what i think is the intercooler has a great big bulge in the bottom and seems to be leaking oil not much oil but there is a little bit all the same, i got pulled by the cops on friday saying i need to get it sorted or else, so i really need some input here cud this bulge in the intercooler be part of the problem??? help !!!!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Firstly, check ALL the hoses for splits or leaks, including the 2 big pipes to / from intercooler and also the little pipes. They may be difficult to spot though.
    What happens if you get someone to rev it whilst you look under the bonnet (warm engine, first)? The intercooler hoses should 'inflate' due to turbo pressure build.
    Jun 2007
    Black Country
    If it is the intercooler thats got a bulge, sounds like there is a major blockage somewhere
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I'm not sure what he means by a bulge in intercooler. Maybe a pic would be useful? Isn't the intercooler metallic? If, a bulge would be difficult to do
    Jun 2009
    Durham
    the bottom of the intercooler is meant to be flat but mine curves the little metal bars that run through the middle of the inter cooler are 3 or 4 times the size they shud be but it only seems to be the bottom 3 that have done this the red line shows where the bulge is
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    red line? what red line?
    Jun 2009
    Durham
    the pic obviosly aint showed up lol well the intercooler is meant to be rectangular but mine is not, the bottom of it has bent downover causing it to be more of an oval shape than rectangular,
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    did you use the uploader?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    would like to see the pic! dont sound to good.
    Jun 2009
    Durham
  1. Black smoke
    By Toze2224 in forum Engine & Drivetrain
    Last Post: 11th October 2012, 17:28
  2. black smoke
    By coooky in forum Engine & Drivetrain
    Last Post: 15th July 2011, 22:24
  3. White smoke after intercooler hose off
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 31st May 2011, 22:35
  4. black smoke
    By harny86 in forum Engine & Drivetrain
    Last Post: 10th February 2010, 20:41
  5. black smoke..
    By rec in forum Engine & Drivetrain
    Last Post: 9th February 2010, 22:17
vectra c intercooler black smoke
