Results 1 to 3 of 3
Thread: front spring poundage
    wirral,merseyside
    Default front spring poundage
    well found out a few days ago i have a front coil spring snaped on my dti sri+have been offered a spring off a very kind member on here but im just trying to find out if ther will be a difference between the poundage on the dti sri springs compared to a petrol sri spring.also do they both lower the car by the same 15mm??
    no good me getting the spring if its going to be different+send the car out of sink
    Easiest way to find out is to get your front axle weight for your car (on the plate on the driver's B pillar, it'll have 1 - xxxx) and then see what the FAW is of the car they came from. If you're in the same range then you'll be okay.
    wirral,merseyside
    on the petrol its 995kg but on mine it says 1075kg is that close enuf to be safe??
  1. front spring
    By billt in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 13:17
  2. Front spring just gone
    By martinhill in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2010, 23:57
  3. Front Spring
    By cooky516 in forum Suspension, Wheels & Brakes
    Last Post: 13th January 2010, 10:19
  4. I think front spring has gone!
    By simonturner1975 in forum Suspension, Wheels & Brakes
    Last Post: 9th December 2009, 18:58
  5. Front spring
    By ed taylor in forum General Chat
    Last Post: 3rd March 2007, 18:45
