Results 1 to 10 of 13
Thread: brake warnin light on
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Default brake warnin light on
    hi lads got the brake warnin light on it is itermittant all the pads and discs are fine think i sin on here some where that you need 2 change the sensor 4 a new one or join the wires togther is this right cheers
    Jun 2009
    northern ireland
    yeah those wires usually become hard and break easily...best way to no which wheel is to cross the wires one wheel at a time till light stays off
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    ok cheers mate so do i join the wires to gether
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    so have all these wheels got brake sensors
    Jun 2009
    northern ireland
    yeah every wheel join the two wires one wheel at a time then check the light youll no which wheel the problems in cause the light will go out
    Regular Member fingers66's Avatar
    Carpe Diem
    Quote Originally Posted by trev16185 View Post
    I thought it was just the front near side that has a sensor
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Quote Originally Posted by fingers66 View Post
    thats right just the passenger front and for how much they are and how quick it is to do it i would just get another rather than messing about with the wires
    Near Warrington
    Only fitted 2nearside on most models,although certain models do have them on both front wheels,its very easy 2strip and join these wires,n then no light on
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    nearside bein the passanger side bit thick with stuuf like that lol so just cut the wire and join them
    [Ex]Admin Duncan's Avatar
    Just to clarify and correct some misinformation in some posts above.
    There is only one wheel that has the brake pad sensor wire on it, and that's the front nearside (passenger side). No models ever had both front wheels that had the sensors, and certainly none ever came with it on all four wheels.
    Facelift models lost the pad sensor feature completely.
    Paul - as already said above, if your pads are looking fine then it's probably the sensor wire starting to disintegrate. Options are either fit a new sensor wire - they're less than a tenner - or cut the end where it goes into the pads and twist them around each other if you don't want to replace the sensor wire.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. 3rd Brake Light
    By myule in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2010, 15:56
  4. brake warnin light help please
    By paulvectrac in forum Handling & Braking
    Last Post: 11th September 2009, 22:10
  5. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
