Thread: car with spanner on dash
    Jun 2009
    northern ireland
    Default car with spanner on dash
    hi i've just noticed after getting my car back form the garage (getting flywheel and clutch rerplaced) that theres a light on the dash of a car with a spanner through it...has anyone else ever come across this or any ideas what the problem is......
    Regular Member jonnynufc's Avatar
    Belfast
    engine management light m8, something mustn't be right
    Jun 2009
    northern ireland
    any ideas as it wasnt on when car was left into garage
    Belfast
    http://www.vectra-c.com/forum/showth...ad+fault+codes
    try this and see how u get on, i wouldn't have a clue m8 but im sure some1 on here would
    Jun 2009
    northern ireland
    cheers ill try read them in the morning
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    its telling u theres a fault on the car and it needs to be plugged in to tech2 to find wot fault it is.
    its prob a sensor they haven't put back correctly.
    May 2006
    scotland
    Does the spanner light stay on when engine running or does it extinguish once running? If it stays on, it is a currently active fault and needs looking at (as above, possibly a sensor connector not mating properly. If it goes out after engine is running, it means there has been a fault but no longer currently there (in this instance, maybe the garage have started the engine with not all sensor connectors connected) in which case, if no further faults are reported, the light will dissapear on its own after approx 1 months of normal driving.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    check to see if they have forgot to re-connect a sensor wire or simular connector/plug, light will go out straight away if re-connected.
    Regular Member djr69uk's Avatar
    Midlands
    i'd give the garage a call and let them sort it out mate. sounds like they've upset something during the swapout
  1. Service Spanner/Oil Can on my dash!
    By VXR CDTi in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2013, 14:42
  2. Spanner on dash
    By adam_starkie in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2011, 12:38
  3. spanner on dash
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2007, 09:36
  4. car with spanner through on dash
    By carp in forum Engine & Drivetrain
    Last Post: 17th May 2006, 15:14
