Results 1 to 2 of 2
Thread: Blocked exhaust
    bristol
    Default Blocked exhaust
    My 2006 150BHP Vectra has a blocked DPF. I can clean it, have it service regenerated and the back pressure is perfect. However when I drive about 100 miles (motorway not slow driving) the spanner light comes on and P1901(75) is logged. When I check the pressure is 70 - 80 kpa (should be 10 or so). It has had new injectors, air mass meter, egr valve, dpf filter, manifold pressure sensor. Does not use oil & fuel consumption is good (45+ on a run). What can it be?
    Oct 2007
    estonia
    what about the same diff.pressure sensor that is giving 70-80kPa ? is the sensor OK. If you replace it, dont forget to let the ECM know that you replaced the sensor. It has to be programmed as is necessary with dpf replacement.
    what does the P1901(75) say?
  1. blocked cat on a 2.0t
    By tomo41 in forum Engine & Drivetrain
    Last Post: 12th June 2011, 22:50
  2. Well, Vectra-c's been blocked now...
    By Leemarksmith in forum General Chat
    Last Post: 16th July 2010, 20:05
  3. Wonder if this guy blocked his egr!
    By John LE in forum The 'Off Topic' room
    Last Post: 21st June 2010, 09:09
  4. Blocked filter in exhaust?? recall??
    By newts678 in forum Engine & Drivetrain
    Last Post: 31st July 2009, 13:11
