Thread: Fault codes ?
    leeds
    Default Fault codes ?
    Hi all in a n earlier posted i talked about exhaust fume light coming on and i have just dont hte trick to find out the engine codes and i got:
    0170
    0302 or 0402
    anyone know what they mean please.
    11 Post(s)
    Try putting them into the search feature on this site and see what comes up.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    P0170 - Fuel Trim Bank 1
    P0302 - Cylinder 2 Misfire Detected
    P0402 - Exhaust Gas Recirculation Flow Excessive Detected
    What engine do you have?
    leeds
    Sorry guys im a bit of a newbie on the site and didnt see the search function.
    Thanks for the replys.
    the codes are 0170 and 0402, my engine is a 1.8sri i also have the exhaust gases light on with these codes.
    What do they mean: P0402 - Exhaust Gas Recirculation Flow Excessive Detected
    Oh also the engine was jetwashed the day before i got these and was wondering if maybe this has caused the problems
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    How long have you had the light on for?
    It may be that water has got into an electrical connection somewhere. I'd check.
    Trim bank 1 is the lambda sensor on top of the catalyst - maybe worth a check of wiring as this sensor would defo get sprayed during jet wash.
    I don't even know where EGR valve is on 1.8
    I'd also check the electrical connection to the MAF.
    Just disconnect, clean and reconnect each connector you see related to these parts
    What year 1.8?
    leeds
    Thanks for the Tips Ste the light came on tuesday .
    its a 2003 1.8 sri.
    i jetwashed it on the previous sunday
    Oct 2009
    yorkshire
    HI i have small problem think exhaust could be on its way out then emissions light came on asked them and they said it would be exhaust doing it checked the code and its the fuel trim bank, but last year the light was coming on every now and again any ideas??????
    Thanks Chris
    By the way its a 52 plate vectra c 1.8 sxi
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
