Thread: Fault codes...
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Default Fault codes...
    Peeps,
    Anyone have the link for the full list of fault codes.
    I recently did Ste's method on pushing in the accelerator and brake pedal. Anyhow after 3 goes of trying to count the flashes I think I have the following codes:
    10 7 10 4
    2 1 10 3
    10 1 7 10
    1 4 1 5
    1 5 5 10
    10 1 9 10
    1 6 3 1
    Don't know if these are correct (hard to count the flashes)....
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    0704 - P0704 - Clutch Switch Input Circuit Malfunction
    2103 - unlisted
    0170 - P0170 - Fuel Trim Bank 1
    1415 - P1415 - Secondary Air Injection (AIR) System Bank 1
    1550 - unlisted
    0190 - P0190 - Fuel Rail Pressure Sensor Circuit
    1631 - P1631 - Theft Deterrent Start Enable Signal Not Correct
    Edinburgh
    ouch
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is your battery in good condition?
    Mar 2007
    NI
    I did run flat a few months back and got it jumped. Hav'nt had any problems since... do you think a new one is needed?
    Also only warning light is the EML which is constant not flashing.... (yet!)
    Also Ste when the eml flashes 10 times is that really a 0 then?
    P0704 - linked to cruise control? The stalk has the cc option yet its only a ls model so thought i did'nt have. Is it a big price to fix?
    Not sure about the rest, could you explain them to me if you have the time!!!!
    Regular Member Jezzy's Avatar
    S.E
    Mar 2007
    NI
    Many thanks....
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by Stevie-B View Post
    clutch switch input 704 would be fairly simple?? does your (if fitted) cruise control knock itself off easily?, just needs minor adjustment to clutch pedal spring, takes about 5 seconds!! as the pedal to switch adjustment maybe in-correct
    Mar 2007
    NI
    Hi Wizard. The CC has never worked while I've owned the car. I thought that the stalk was added to all vechicles so that if the CC option was taken it would be a simple job to add on in the garage.
    I might need to look at tech 2 to get the full list of codes as the method I employed was from Ste which although excellent to give an idea is hard to keep track of the flashes...
    I'm slighty worried in the fuel fault code.
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
