Hi guys been a while since is been on here,i put down the drivers window and there was a load bang then when it went up it went up at an angle,i tried it several times and id kept doing the same eventually it just fell down and i removed the door card and the arm that is connected to the window is bent and the window is of the runner,it also looks like that a rivot or 2 has snapped of and the motor mechanism is not held onto the door,is there a guide to fixing the drivers side or a pic of the rivots and where they are supposed to go,iv got the window pushed up into the rubber and a piece of wood jammed underneath so that it stays up until i can fix it or get it fixed.
