Results 1 to 10 of 24
Thread: Limp mode - no power :(
    Edinburgh
    well my precious Vectra went into limp mode while I was driving my wife to work and all power is gone, I can barely go up hills in it. Plus the engine seems to judder a bit even when idling. Going to read the codes but well ****ed off had to turn round and limp all the way home. Engine sounds a bit noiser too. The EML is on and goes on and off but it doesn't come out of limp mode and the EML pretty much comes straight back on when it goes out.
    I'm not having as bad a day as another Vectra driver, while limping home I was sitting at traffic lights at J3 of M8 and another Black Vectra rear ended a flatbed truck. doh!
    Off to try and read the codes now......
    1.9 CDTi 150 btw. at least my swirl flaps appear to still be attached.
    Full Member spennny's Avatar
    Blantyre
    Have you checked all the vacum pipes mate, would be my first port of call,
    Edinburgh
    Managed to get the code off it at last:
    P0203 - Injector 3 Control Circuit
    There appears to be a subcode of -04
    This rings a bell, i'm sure I've seen something mentioned about this before.
    Could this be what I need?
    http://www.vectra-c.com/forum/showthread.php?t=73584
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Certainly a good place to start mate... can make the car run awful when faulty - trust me !!
    Edinburgh
    yeah it does, I can't really get it above 45mph atm and it almost slows down when going up a hill. pretty much undriveable.
    I do have a Tesco warranty so I'm not sure whether to just stick it in the dealers and let it get handled under warranty or whether to just plash out £12 and do it myself save the dealer having it for several days.
    Lancashire
    Trim : XP1
    Mileage : 66000
    You could just spray some contact cleaning in injector plug number 3, and see if its any better, might only be temporary but should point to the problem.
    Edinburgh
    am I ok to drive it in it's current state? ie to Halfords/B&Q or stealer if needed?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by knoxvillain View Post
    When mine went the car was only used for short journeys and it was fine, so you should be ok for short runs.
    Glasgow Scotland
    intresting my 19cdti goes into limp mode if she goes over 3000 revs.If i turn it off and restart if goes ok.Noticed last night my swirl flaps appear lying disengadged at the side of the block feeling rather sorry for them selfs.Is therea fix for this?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by big peachy View Post
    Err, you won't like the answer to that question
  1. Power loss like limp mode no code/light
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 19th March 2013, 10:27
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 30th July 2010, 20:41
  5. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
