Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: IT help, home wetworking
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default IT help, home wetworking
    I want to access my desktop from my laptop, so to share files etc.
    The desktop runs XP Home, and the Laptop runs Vista.
    Both are connected via ethernet cables to a hub with wireless too (switched off at presemnt) and both access internet just fine.
    I have set both to the same workgrioups name, and 'shared' 2 folders on desktop, but cannot access them at all from Laptop, or even setup the sharing thing.
    Help me, please
    Plymouth
    ive heard that XP and Vist will not work together at all!
    Go to bed as it's very late try again tomorrow hth ..................
    Worcs/Staffs/Westmids (ish)
    Try turning off your firewalls, windows or otherwise.
    Full Member spennny's Avatar
    Blantyre
    You lot the nightshift on here ??
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    XP & Vista will work together (providing a couple of dependencies are met).
    Ste, from your desktop (XP) can you see the 'Sharing & Security' option when you right click the folder you want to share - then select the 'Share this folder' radio button and give it a share name (it defaults to the folder name usually) leave the share permissions alone as these should be left as they are (everyone = read) and the security should be locked down by the security tab - now, you will only have this security tab if the drive in which you are sharing folders on has been formatted in NTFS format - FAT16 etc you won't be able to set permissions - which thinking about it, this is probably what the problem is.
    What format is the drive in Ste..? (Right click the c: / d: etc in My Computer then click properties - and it will be listed next to 'File System').
    Regular Member LJ sxi-nav's Avatar
    Winchester
    Quote Originally Posted by Birchy63 View Post
    My set-up uses 2 XP PC's. When I first them up, the shares were not visible between the PCs and I couldn't work out why. Eventually turned off Zonealarm and it worked! I've since reconfigured/re-enabled ZA to allow network traffic between the PC's.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    FAT 32, running windows firewalls
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Ste View Post
    Being FAT32 you will only be able to share a directory, and therefore everything within (and maybe password protect it) but you can't narrow down to specific files/folders etc. You would need NTFS for that but, the share method should be the same as above.
    The firewalls could be causing problems, especially so if they are 3rd party ones.
    If you wanted to convert your drive to NTFS, you can do it by doing the following:
    From a command prompt type "convert drive letter: /fs:ntfs
    (If the operating system is on the drive that you are converting (which it more than likely will be), it will ask you to schedule the task when you restart the computer because the conversion cannot be completed while the operating system is running. just click yes.
    You'll get a message like "The type of the file system is FAT." and it will ask you to enter a name for the volume, then once done, you receive a message saying its complete.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What's the difference between folders and directories?
    Sharing the entire drive would be fine, I just wanted to do it a bit more cleanly.
  1. egr blanked - 2000 miles and no limp home home
    By jonestown in forum Y & Z30DT Specific
    Last Post: 1st August 2012, 14:55
  2. Replies: 71
    Last Post: 30th April 2008, 12:38
  3. ah! home sweet home!
    By pogo in forum General Chat
    Last Post: 20th October 2007, 21:03
  4. Home Air Con
    By bandrew in forum General Chat
    Last Post: 11th June 2006, 20:30
  5. home sweet home aarrrrggg i love it !!!!
    By big phil in forum Introduce yourself.
    Last Post: 9th June 2005, 08:04
