Thread: vec c stalled can anyone advise me
    Regular Member denzilbud's Avatar
    cambridge
    Default vec c stalled can anyone advise me
    hi all ran in to another problem today with my vec c 2.2 sri(52)plate,i was coming to a junction in the road when revs dropped and died so i started the engine again and the engine was running as if it was missing then i gave it a little rev and it cleared,would this be the plugs and leads?one thing that is bothering me is when the car stalled i had air con wacked on full but when i started the engine again there was no power to the heaters only lasted a couple of mins then the air started blowing again why would this of happend any help would be great
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Its a coil pack on the 2.2 mate, no leads. Has there been other symptoms at all? Is it running sweet as a nut normally or do the revs drop quite often when your coasting? Is there any misfiring?
    cambridge
    hi mate revs are constantly low and there doesnt seem to be any powerthrough the first few gears
    cambridge
    and the first time it miss fired was today when it stalled
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    The revs should be about 700rpm when warm. Check the cheapest things first like plugs and cleaning the throttle body, but TBH I dont think it could be the TB. Unless you get your cods read your going to have to move on to coil pack and even the o2 sensor, did the emissions light come on?
    cambridge
    no emissions light nothing just stalled because of low revs started it again wouldnt start first time of trying ignition then second attempt it started but was missing so i gave it a little rev and it cleared
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Sorry mate, just been having a game of COD LOL.
    Its a long shot but get the Tb off and give it a clean. The tick over is controlled by the flow of air through a gap where the butterfly doesn't quite seat properly in the barrel of the Tb. This gets coked up and can induce stalling but it doesn't just happen, it gradually gets worse. There is a how 2 for it HERE mate. Its a 10 minute job to get it unbolted.
    cambridge
    hi there yeh used your thread already as you advised me to do this the other day and no improvment do you recon its worth getting a second hand coil pack and will they be the same on any z22se engine ie vectra,astra,omega cheers
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    LOL, I didnt make the connection in the 2 threads.Omega is a X22SE not Z22SE iron block so don't be getting an omega one. You should be fine with a Vec B, Zaffy A, Astra G. don't get a Vectra C estate or signum one as that's a Z22YH.
    Have you posted on the 2.2 forum (z22se.co.uk), there are guys with far more knowledge over there all willing to share the experience.
    cambridge
    nice one cheers mate
  1. Need Some Advise
    By spennny in forum The 'Off Topic' room
    Last Post: 29th March 2011, 13:52
  2. revs up and down the stalled
    By MORGIE8153 in forum Engine & Drivetrain
    Last Post: 23rd September 2010, 10:16
  3. Looking for some advise
    By Gortreck in forum Engine & Drivetrain
    Last Post: 17th September 2009, 12:46
  4. Car went in big puddled and stalled and wouldnt start for ages
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 18th July 2009, 00:14
  5. advise
    By steeb82 in forum General Chat
    Last Post: 6th March 2009, 01:00
