Thread: Temp Sensor
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Default Temp Sensor
    According to my temp sensor, the temp for the last few weeks has been
    +87deg C. Now, obviously it is faulty, but any ideas as to what part? The resistance of the temp sensor varies with the temp( connected it to an Ohmeter and it varies with the temp......)
    I'm due in for the 60,000 mile service within the next month, so I'll get the mainstealers to sort it out then, just thought i'd put this one to you as someone may have an easy/obvious fix.
    P.S. On another thread can anyone let me know what I should ask to be done/looked at one the 60,000 mile service? As this will effectivly be the end of my warranttee, i need to get anything that can go wrong sorted before it does!!!
    P.S. If any moderators would like to copy this to any service related threads then please do, as I can't seen to find one on any regular service related issues. :-) Cheers Guys.
    Live long and prosper,
    Ghostrider..
    Regular Member david173's Avatar
    Dec 2005
    Dumbarton, Scotland
    Mines was stuck at about 70C since I got it, fixed under warranty in less than an hour no bother, just a replacement sensor
    Regular Member thewww2's Avatar
    London
    cant you borrow a sensor from another vauxhall owner just to see if it your sensor thats faulty , i dont reckon they are that expensive , got to be cheaper that dealer checking it.
    sensor failure is commonplace.. it's clipped to the inside of the front lower grille.. for some reason they all fail high/open circiut.. replacement is a five minute job, just a plug and a clip.
    Dec 2005
    In the sponge-monkey tent
    They sometimes just need resetting or recalibrating, especially after a service, not sure what they do that throws them off but had the problem on my Astra and again on this Vectra.
    Dec 2005
    Dumbarton, Scotland
    Vauxhall thermometers seem to have always been s**t, my '96 Astra's was all over the place, I thought maybe they had got better when unbeliavably I had the one in the Corsa for three years and not a single fault, but lo and behold the Vec proved they were still awful! My friend has just got use of an old 96' Astra the reading isnt even wrong its just --.-
    Very helpful!
    Never had a problem with 4 Vx' over 8 years of ownership... Corsa B, Astra F & G and Vec C.... all thermometers been fine.
    All my mates (8) Vec B's thermometers work fine too!!
  1. outside temp sensor
    By andy_richmond in forum Troubleshooting
    Last Post: 30th September 2012, 14:09
  2. Outside Air temp sensor........
    By Mark@Elite in forum Troubleshooting
    Last Post: 4th February 2012, 16:20
  3. Temp sensor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 21:23
  4. Outside temp sensor
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 17:35
  5. Outside temp sensor
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 18:29
