Thread: claying question
    Regular Member signum03's Avatar
    worthing
    confused claying question
    evening, when i bought the mcguires clay kit i used all of the quick detailer and still have a clay bar left, is there another solution you can use as i have been to halfords and they dont sell quick detailer? will halfords sell someting similar on there shelf??? thanks in advance
    Mileage : 000
    You could try car shampoo/wash. All you need is a good lubricant to stop the clay bar from sticking to the paintwork. I have tried shampoo/wash. It does work, but not as good but give it a try. Put plenty od soap/shampoo in the "mix" with water and see how it goes. As long as the clay doesn,t "drag" ( start to leave bits stuck to the paint) then you should be ok.
    Regular Member Cossy's Avatar
    East Yorkshire
    Most spray detailers or detailing lube will do! There are quite a few clays out there which are very soft and you can just use water with them...these are always worth the investment i've found as they do the job abit better than the clay kit as they are softer.
    worthing
    being nieve i thought your had to soften the sap, tar etc with the detailer, how will car shampoo do that????
    Regular Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    as cossy said, Any quick detailer.
    http://shop.ebay.co.uk/items/__quick...detaier?_rdc=1
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    the detaailer is simply a lube... the clay is what lifts and traps the contaminents.. the quick detailer doesnt do anything but help the clay 'glide' over the surface of the paint
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    i use bilt hamber clay bar which only requires water mate although i make sure panels are soaking so theres no drag,ive used megs clay in the past and it does require quick detailer too lube it,i bought some carplan demon shine QD at the weeken d for a fiver out of tesco and it would be fine for your lubunig requirements hth mate
    Regular Member david.aka.judas's Avatar
    Suffolk
    m8 - I use megs clay and I mix up a solution of shampoo and water and it works gr8.
    save you loads of cash.
    try this - www.detailingworld.co.uk
    ask any question - loads of advice.
    Regular Member Wilco's Avatar
    Aug 2007
  1. New to claying
    By johnny1983 in forum Detailing and Car Care Discussion
    Last Post: 25th March 2011, 13:45
  2. Claying question
    By davidj387 in forum Detailing and Car Care Discussion
    Last Post: 4th July 2010, 21:00
  3. Qick claying question
    By TomiboyC in forum Detailing and Car Care Discussion
    Last Post: 27th March 2010, 23:36
  4. what to do after claying car?
    By vectragsi3.2 in forum Detailing and Car Care Discussion
    Last Post: 15th February 2009, 16:08
  5. what is claying and what does it do
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2008, 10:47
