Thread: rear brake rewind tool
    wirral
    Default rear brake rewind tool
    hi all
    i just bought the laser tool 1314 and adapter 4057 to do my rear brakes and the adapter is totally the wrong one even thou advertised as being for vectra has anyone had the same problem ?? and know what the correct adapter is for the rears
    thanks lee
    wirral
    Default brake tool
    just spoke to laser tools technical and they saying adapter 3104 will fit the later vectra even thou its not listed anywhere as being for the vectra or saab 93 (4mm pins and 20mm centres)
    Nottinghamshire
    Your other option - if you can and want to return the kit you have now - is the one below.
    "Brake Caliper piston rewind tool with two adaptors for Vauxhall/Opel Zafira/Zafira CNG/Vectra-C/Signum/Corsa-C Combo/Corsa-C/Astra-G/ Cabrio/Astra-G/Astra-H/Astra & Caravan CNG"
    http://www.lasertools.co.uk/item.aspx?cat=518&item=3788
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    I had the same problem - I ended up cutting the pins off, drilling and tapping two holes the correct distance apart, and fitting a couple of cut down bolts as new pins.
    Yes, some hassle, but at 19:30 in the evening, in the middle of the country, with the car on axle stands...........
    Regular Member mark the hat's Avatar
    Jan 2008
    manchester
    same problem here just got the grider out and knibbed the pins down from the outside in a bit at a time till it fitted .....job done
    mark
    Regular Member Baz07's Avatar
    Lancashire
    Quote Originally Posted by James24 View Post
    Found the same one on Ebay, a bit cheaper..
    This is the one i purchased and it did the job..HTH
    Apr 2009
    bromsgrove
    Quote Originally Posted by mark the hat View Post
    mark
    i did exactly the same works fine
  1. Brake rewind tool (which one)
    By Middo in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2011, 17:27
  2. Rear brake rewind tool thread pitch
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 13:03
  3. brake rewind tool
    By stuartbat in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2009, 12:36
  4. Rear brake rewind tool
    By Nickzx6r in forum Parts for sale
    Last Post: 24th November 2007, 17:37
vectra c laser 1314
vauxhall rear brake tool
vectra c brake rewind tool
