Thread: Windscreen wipers smearing help please....
    St Neots
    Default Windscreen wipers smearing help please....
    Hi Guys
    My girlfriends ka is causing problems with its wipers. When you use them you get a 2/3 inch wide smear across the screen on the drivers side. Tried 2 sets of wipers and made no difference. Cleaned with windowlean 3 times and degreased and still no difference. When you spray the washers it leaves a rainbow effect on the screen which suggests to me there is oil on it but cant seem to shift it
    Any ideas???
    Thanks Tom
    Regular Member stuball's Avatar
    Aberdeen
    flush out the tank a few times with hot water then repeat all of above again!
    St Neots
    cheers ill give that a go
    sorry if it sounds thick but how is this done
    Regular Member barkzz's Avatar
    Quote Originally Posted by tom_p_2000 View Post
    Stick hot water in the washer fluid bottle.
    Failing that, stick some very weak fairy liquid in, but rinse it out after with ordinary water
    Regular Member big O's Avatar
    Good old Sunny Scunny!!!!
    flush your tank, and put some vinegar on a cloth and wipe your wipers with it, that will get rid of all the grease off your wipers.
  1. Windscreen wipers
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2012, 18:31
  2. Badly smearing windscreen
    By NealM in forum Detailing and Car Care Discussion
    Last Post: 22nd December 2010, 19:45
  3. Windscreen Wipers
    By Pete32 in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2010, 13:35
  4. Windscreen wipers
    By Q22ube in forum Engine & Drivetrain
    Last Post: 10th December 2008, 21:11
  5. Windscreen wipers
    By *VECTRA 1.8 SatNav* in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2007, 01:10
