Results 1 to 10 of 19
Thread: Idle Speed Now 1200RPM 3.2 V6 - Done The Usual
    Regular Member Hedgehog70's Avatar
    Yorkshire
    Default Idle Speed Now 1200RPM 3.2 V6 - Done The Usual
    Car had a basic service at Stealers due to a lack of time. In the 3 weeks since I have cleaned the throttle body, replaced the gasket, replaced the air filter and changed the spark plugs.
    All has been fine since last Thursday when I did the plugs, that is until tonight when the idle (tickover) has decided to settle at around 1200RPM and feels to stay open more than usual between gear changes.
    Any ideas?
    TONY
    Regular Member barkzz's Avatar
    Unhappy
    Quote Originally Posted by Hedgehog70 View Post
    Any ideas?
    TONY
    Id have put money on throttle body but you have already done it
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    Sounds like a possible air leak causing it to hold the revs up. Is their any other faults? Does the temperature gauge work?
    Yorkshire
    Quote Originally Posted by sdemps View Post
    Temp gauge is operating normally
    T
    Nov 2007
    Ayrshire
    Could be a vacuum hose come off or something silly. Hope it's nothing serious.
    Yorkshire
    Can't see any hoses off - The only thing that brings the idle speed down is putting the A/C on!!
    TONY
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    TONY
    Mine too mate
    Regular Member 30ltr nutter's Avatar
    dunstable
    has it had any warnings lights on some faults leave the revs high until the error has been cleared i hope this helps
    Yorkshire
    No mate - No warning lights on at all and not had any.
    TONY
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by andymagee1982 View Post
    Mine too mate
    Looks like we have found the problem to yours mate
  1. High idle speed
    By 19CDTi in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:02
  2. 1.8 Idle speed
    By cpt slow in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2011, 14:43
  3. Idle Speed?
    By Badger59 in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2010, 13:29
  4. ajusting idle speed
    By Morephun in forum Petrol Engine related
    Last Post: 17th February 2009, 19:36
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
vevtra c 3.2 v6 holds revs between gears
