Results 1 to 10 of 16
Thread: Does cruise control apply braking for you?
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    Default Does cruise control apply braking for you?
    as titled,
    I have been wondering this for a while now, not sure if its just the fact its a diesel or if my car is actually breaking for me slightly when going down hill?
    Also my car has front and rear parking sensors and as im not brave/stupid enough to get close enough to someone, would it sense an impact and turn c/c off and slightly brake.
    If it helps my car has c/c s/m t/c eps etc etc.
    Thanks all
    Regular Member Robbie69's Avatar
    No it won't I think it just cuts power if you start going too quick. It WILL not brake if you get too close to other cars. There are cars on the market that have this feature, not the Vectra though.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If you're on cruise and you go down a descent sufficient that the car speeds up, you will notice a manual will retard the fuel slightly and induce engine braking. An auto will drop a gear as well in some cases as the cruise management attempts to maintain the set speed.
    You might have noticed that the parking sensors start beeping with an obstruction around 50cm away maybe slightly less. While moving even at say 20mph, you would cover that distance in a fraction of a second. Besides, to activate the park assist system you must be below 15mph and select select reverse (unless you manually activate it)..... how fast do you plan on reversing ??
    [Ex]Admin Duncan's Avatar
    As above, CC will not activate brakes, it will only induce engine braking as long as you're in the right gear i.e. if you're in fifth gear and heading downhill, you'll just keep getting faster and faster as you won't be in the right gear, for the speeds you'd be doing, to have any engine braking.
    Regular Member solorider's Avatar
    swindon
    my last vectra c which was a 3.0 cdti auto while going down hill with c/c on the c/c would disengage after a period of time (ie down a long hill) i have not tried my present vectra on a long hill
    Regular Member benny's Avatar
    Feb 2006
    dudley
    pmsl
    Feb 2006
    dudley
    Regular Member hagga's Avatar
    kingswinford
    Does cruise control break for me... Yes..it never ****** works lol (clutch switch me thinks)
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    CC won't brake or slow the car down. http://www.vectra-c.com/forum/showth...ghlight=cruise
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The only braking force will be engine braking, if that isn't enough for the descent then you will speed up. Conversely, if the hill is too steep to climb in the gear you are in, then your speed will decrease even if the CC requests full power. Obviously the amount of power and engine braking will change from engine to engine
  1. Cruise control
    By suggs1971 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2009, 14:52
  2. cruise control
    By sristeven1 in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 25th August 2009, 20:19
  3. cruise control
    Last Post: 24th August 2009, 22:03
  4. Cruise Control 2.0 T
    By neilbroad in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2008, 19:24
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
does vectra c cruise control use the brakes
