Thread: Strange noise from vents (I think)
    Fife
    Default Strange noise from vents (I think)
    Hi guys,
    I'm a bit confused by the new sound I'm getting at higher speeds (60 / 70mph) - yep, I'm in the 'noise freeks club'. Sounds like someone was playing with some tin foil.
    It's definately caused by the air flow - I guess somewhere behind the console. Everything indicates on leafs in vents (the stealers have replaced the airfilter recently and may have let few bits to go into the air hoses).
    The question is - would blowing some air in the hoses from under the bonnet help (after taking out the airfilter)? perhaps I should blow some air from the inside? I'm not sure how is the blower build and I don't know if the rubbish is going to fall out inside the car or just stuck to the fan mechanism or anything else on their way.
    My exhaust is also a bit rusty, but I doubt if it actualy causes the noise - the catalyst converter has crossed my mind, but the revs don't seem to have any impact on the noise.
    Anyway, I'd appreciate if someone shares some knowledge about taking leafs out the vents.
    cheers
    Regular Member Vectralicker's Avatar
    Fife - unfortunately
    Quote Originally Posted by gr8crow View Post
    Hi guys,
    cheers
    im not quite sure what would be the problem but would love to see your neighbours faces as you blow through a pipe, on your driveway, into you cars engine bay, checking for tin foil noises??.........
    Fife
    Quote Originally Posted by Vectralicker View Post
    If it means not paying the Stealers £50 for 'sorry no fault found'- hell, I'm going to go for it
    they would think I'm cleaning the engine anyway :P
    Fife
    anyway, let's make it clear - I mean - 'blowing some high pressure air'
    I wasn't going to whistle to the engine ))
    aw u have ruined the imagery now! lol
    hope you make it to falkland performance on the 27th lad.
    Perhaps we can all have a listen and take a guess as to what the issue is!
    Mar 2007
    Bristol
    mine was making a high whistling sound the other week. quick trip to the stealers saw a new compressor and regas which sorted out the problem. Shame they forgot to refit the egr valve properly which caused exhaust gas to come into the cabin through the newly fixed aircon system.
  1. Insignia noise through air vents
    By vinnieac in forum Engine & Drivetrain
    Last Post: 26th October 2014, 15:54
  2. Need help with strange noise
    By tony-1977 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th January 2013, 18:04
  3. help with strange noise???
    By Mads in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2011, 21:15
  4. Strange Noise
    By johnny1983 in forum Engine & Drivetrain
    Last Post: 22nd June 2009, 20:54
  5. strange noise???
    By dave16v in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2007, 22:11
