Thread: Is 6 to 7 degrees C ok for air con temp
    May 2006
    scotland
    Default Is 6 to 7 degrees C ok for air con temp
    All, just had my aircon regassed and it is now 6 to 7 Degrees C with aircon on (with a temp probe in the front vent) does this sound about correct??
    thanks
    Edinburgh
    sounds pretty decent imo
    Mileage : 000
    It would be very comfortable in the hot weather. I don,t think I have had mine that low though.
    Regular Member bigbnlr's Avatar
    Belfast
    yep sounds lovely
    Sunny Dartmoor
    Would love mine that cold..........
    Cambridgeshire
    sounds good mate, land rover officially recommend 5c or lower for all their cars so 6 or 7 is perfect!!!
    Regular Member Readster's Avatar
    Plymouth
    thought it was supposed be -2 when the AC was working properly?
    Quote Originally Posted by Readster View Post
    Depends on the outside temperature I suppose - but as long as you're happy with the temp of the air that comes out then the actual temperature is meaningless...
    Regular Member old cruiser's Avatar
    slough
    Had mine down to 4c with recirc flap closed and fan setting 1 after having run aircon at fan setting 3 for a while, as far as I know mine has never been regassed either since new!!
    Cheers Pete
    Regular Member cabbage's Avatar
    Bristol
    Never seen the vent temperature drop below 9 degrees when the AC is set at 19 degrees.
    But by the time it's got down to 9 degrees the temperature in the car has started to fall rapidly and the fan speed starts to decrease.
    Maybe if the AC was set at minimum the vent temperature would go lower.
  1. 22 Degrees last week...............
    By Das in forum General Chat
    Last Post: 4th April 2012, 08:47
  2. 22 Degrees!
    By KSD in forum General Chat
    Last Post: 31st March 2012, 19:09
  3. P0400 when ambient temperature is above 12 degrees.
    By jtg in forum Vectra C / Signum Troubleshooting
    Last Post: 27th November 2011, 18:41
  4. Caught in the act finally! 610 degrees C!!
    By hebblemarine in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2011, 07:39
  5. Wipers parking @ 80 degrees
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2009, 14:20
